On First-Order Topological Queries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Computational Logic Année : 2002
Luc Segoufin
One important class of spatial database queries is the class of topological queries, that is, queries invariant under homeomorphisms. We study topological queries expressible in the standard query language on spatial databases, rst-order logic with various amounts of arithmetic. Our main technical result is a combinato-rial characterization of the expressive power of topological rst-order logic on regular spatial databases.
topo-FO.pdf (349.88 Ko) Télécharger le fichier
hal-01223388 , version 1 (02-11-2015)
Martin Grohe, Luc Segoufin. On First-Order Topological Queries. ACM Transactions on Computational Logic, 2002, 3 (3), ⟨10.1145/507382.507384⟩. ⟨hal-01223388⟩
Collections
CNRS INRIA INRIA2
62 Consultations
132 Téléchargements
