A fast and simple randomized parallel algorithm for the maximal independent set problem, Journal of Algorithms, vol.7, issue.4, pp.567-583, 1986. ,
DOI : 10.1016/0196-6774(86)90019-2
Network decomposition and locality in distributed computation, 30th Annual Symposium on Foundations of Computer Science, pp.364-369, 1989. ,
DOI : 10.1109/SFCS.1989.63504
Deterministic (? + 1)-coloring in sublinear (in ?) Time in Static, Dynamic and Faulty Networks, Proc. 34th ACM Symp. on Principles of Distributed Computing (PODC), pp.345-354, 2015. ,
Sublogarithmic distributed MIS algorithm for sparse graphs using Nash- Williams decomposition, Proc. 27th ACM Symp. on Principles of Distributed Computing (PODC), pp.25-34, 2008. ,
DOI : 10.1007/s00446-009-0088-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.218.5312
Distributed (? + 1)-coloring in linear (in ?) time, Proc. 41th ACM Symp. on Theory of Computing (STOC), pp.111-120, 2009. ,
Deterministic distributed vertex coloring in polylogarithmic time, Proc. 29th ACM Symp. on Principles of Distributed Computing (PODC), pp.410-419, 2010. ,
Distributed Graph Coloring: Fundamentals and Recent Developments. Synthesis Lectures on Distributed Computing Theory, 2013. ,
DOI : 10.2200/s00520ed1v01y201307dct011
Distributed $(\Delta+1)$-Coloring in Linear (in $\Delta$) Time, SIAM Journal on Computing, vol.43, issue.1, pp.72-95, 2014. ,
DOI : 10.1137/12088848X
The locality of distributed symmetry breaking, Proc. 53rd IEEE Symp. on Foundations of Computer Science (FOCS), pp.321-330, 2012. ,
An Exponential Separation between Randomized and Deterministic Complexity in the LOCAL Model, 2016 IEEE 57th Annual Symposium on Foundations of Computer Science (FOCS) ,
DOI : 10.1109/FOCS.2016.72
Choosability in graphs, Proc. West Coast Conf. on Combinatorics , Graph Theory and Computing, Congres. Num. 26, pp.125-157, 1979. ,
Deterministic Stateless Centralized Local Algorithms for Bounded Degree Graphs, Proc. 22nd Annual European Symposium on Algorithms (ESA, pp.394-405, 2014. ,
DOI : 10.1007/978-3-662-44777-2_33
Randomized Local Network Computing, Proceedings of the 27th ACM on Symposium on Parallelism in Algorithms and Architectures, SPAA '15, pp.340-349, 2015. ,
DOI : 10.1145/2755573.2755596
URL : https://hal.archives-ouvertes.fr/hal-01247357
Towards a complexity theory for local distributed computing, Journal of the ACM, vol.60, issue.5, p.35, 2013. ,
DOI : 10.1145/2499228
On the complexity of distributed graph coloring with local minimality constraints, Networks, vol.9, issue.1, pp.12-19, 2009. ,
DOI : 10.1002/net.20293
URL : https://hal.archives-ouvertes.fr/inria-00200127
Distributed list coloring: how to dynamically allocate frequencies to mobile base stations, Proceedings of SPDP '96: 8th IEEE Symposium on Parallel and Distributed Processing, pp.18-25, 1996. ,
DOI : 10.1109/SPDP.1996.570312
URL : http://hdl.handle.net/11858/00-001M-0000-0014-A198-B
Parallel Symmetry-Breaking in Sparse Graphs, SIAM Journal on Discrete Mathematics, vol.1, issue.4, pp.434-446, 1988. ,
DOI : 10.1137/0401044
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.39.269
Linear-in-Delta lower bounds in the LOCAL model, Proc. 33rd ACM Symp. on Principles of Distributed Computing (PODC), pp.86-95, 2014. ,
Distributed (???+1)-coloring in sublogarithmic rounds, Proceedings of the 48th Annual ACM SIGACT Symposium on Theory of Computing, STOC 2016, 2016. ,
DOI : 10.1145/2897518.2897533
Distributed maximal matching, Proceedings of the 2012 ACM symposium on Principles of distributed computing, PODC '12, pp.165-174, 2012. ,
DOI : 10.1145/2332432.2332464
Toward more localized local algorithms, Proceedings of the 30th annual ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '11, pp.5-6, 2013. ,
DOI : 10.1145/1993806.1993814
URL : https://hal.archives-ouvertes.fr/hal-01241086
Weak graph colorings, Proceedings of the twenty-first annual symposium on Parallelism in algorithms and architectures, SPAA '09, pp.138-144, 2009. ,
DOI : 10.1145/1583991.1584032
What cannot be computed locally!, Proceedings of the twenty-third annual ACM symposium on Principles of distributed computing , PODC '04, pp.300-309, 2004. ,
DOI : 10.1145/1011767.1011811
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.5623
On the complexity of distributed graph coloring, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, pp.7-15, 2006. ,
DOI : 10.1145/1146381.1146387
A Simple Parallel Algorithm for the Maximal Independent Set Problem, SIAM Journal on Computing, vol.15, issue.4, pp.1036-1053, 1986. ,
DOI : 10.1137/0215074
Converting Online Algorithms to Local Computation Algorithms, Proc. 39th Int. Colloq. on Automata, Languages, and Programming (ICALP), pp.653-664, 2012. ,
DOI : 10.1007/978-3-642-31594-7_55
URL : http://arxiv.org/abs/1205.1312
A Local Computation Approximation Scheme to Maximum Matching, proc. 16th APPROX-17th RANDOM, Springer LNCS 8096, pp.260-273, 2013. ,
DOI : 10.1007/978-3-642-40328-6_19
URL : http://arxiv.org/abs/1306.5003
Graph coloring problems and their applications in scheduling. Periodica Polytechnica Ser, El. Eng, vol.48, issue.1, pp.11-16, 2004. ,
A Lower Bound on Probabilistic Algorithms for Distributive Ring Coloring, SIAM Journal on Discrete Mathematics, vol.4, issue.3, pp.409-412, 1991. ,
DOI : 10.1137/0404036
What Can be Computed Locally?, SIAM Journal on Computing, vol.24, issue.6, pp.1259-1277, 1995. ,
DOI : 10.1137/S0097539793254571
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.28.902
Constant-Time Approximation Algorithms via Local Improvements, 2008 49th Annual IEEE Symposium on Foundations of Computer Science, pp.327-336, 2008. ,
DOI : 10.1109/FOCS.2008.81
Improved distributed algorithms for coloring and network decomposition problems, Proceedings of the twenty-fourth annual ACM symposium on Theory of computing , STOC '92, pp.581-592, 1992. ,
DOI : 10.1145/129712.129769
Approximating the minimum vertex cover in sublinear time and a connection to distributed algorithms, Theoretical Computer Science, vol.381, issue.1-3, pp.183-196, 2007. ,
DOI : 10.1016/j.tcs.2007.04.040
Distributed Computing: A Locality-Sensitive Approach, SIAM, 2000. ,
DOI : 10.1137/1.9780898719772
T-colorings of graphs: recent results and open problems, Discrete Mathematics, vol.93, issue.2-3, pp.229-245, 1991. ,
DOI : 10.1016/0012-365X(91)90258-4
Fast local computation algorithms, Proc. Innovations in Computer Science (ICS), pp.223-238, 2011. ,
Survey of local algorithms, ACM Computing Surveys, vol.45, issue.2, p.24, 2013. ,
DOI : 10.1145/2431211.2431223
Locality based graph coloring, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.201-207, 1993. ,
DOI : 10.1145/167088.167156
Coloring the vertices of a graph in prescribed colors, Diskret. Analiz, vol.29, pp.3-10, 1976. ,
List-coloring based channel allocation for open-spectrum wireless networks, VTC-2005-Fall. 2005 IEEE 62nd Vehicular Technology Conference, 2005., pp.690-694, 2005. ,
DOI : 10.1109/VETECF.2005.1558001
List-coloring of interval graphs with application to register assignment for heterogeneous register-set architectures, Signal Processing, vol.83, issue.7, pp.1411-1425, 2003. ,
DOI : 10.1016/S0165-1684(03)00089-6
