Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Parsimonious Labeling
Abstract : We propose a new family of discrete energy minimization problems, which we call parsimonious labeling. Our energy function consists of unary potentials and high-order clique potentials. While the unary potentials are arbitrary, the clique potentials are proportional to the diversity of the set of unique labels assigned to the clique. Intuitively, our energy function encourages the labeling to be parsimonious , that is, use as few labels as possible. This in turn allows us to capture useful cues for important computer vision applications such as stereo correspondence and image denoising. Furthermore, we propose an efficient graph-cuts based algorithm for the parsimonious labeling problem that provides strong theoretical guarantees on the quality of the solution. Our algorithm consists of three steps. First, we approximate a given diversity using a mixture of a novel hierarchical P n Potts model. Second, we use a divide-and-conquer approach for each mixture component, where each subproblem is solved using an efficient α-expansion algorithm. This provides us with a small number of putative la-belings, one for each mixture component. Third, we choose the best putative labeling in terms of the energy value. Using both synthetic and standard real datasets, we show that our algorithm significantly outperforms other graph-cuts based approaches.
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01223973
Contributor : M. Pawan Kumar Connect in order to contact the contributor
Submitted on : Tuesday, November 3, 2015 - 5:24:27 PM
Last modification on : Friday, January 21, 2022 - 3:01:22 AM
Long-term archiving on: : Thursday, February 4, 2016 - 11:27:37 AM
File
DK-ICCV2015.pdf
Identifiers
Citation
Puneet Kumar Dokania, M. Pawan Kumar. Parsimonious Labeling. ICCV 2015 - International Conference on Computer Vision 2015, Dec 2015, Santiago, Chile. ⟨10.1109/ICCV.2015.205⟩. ⟨hal-01223973⟩
Share
Metrics
Record views
190
Files downloads
110
