Expressive Equivalence and Succinctness of Parametrized Automata with respect to Finite Memory Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We compare parametrized automata, a class of automata recently introduced by the authors, against finite memory automata with non-deterministic assignment, an existing class of automata used to model services. We prove that both classes have the same expressive power, while parametrized automata can be exponentially succinct in some cases. We then prove that deciding simulation preorder for parametrized automata is EXPTIME-complete, extending an earlier result showing it in EXPTIME.
FOR-MOVES_2015_paper_1.pdf (411 Ko) Télécharger le fichier
hal-01224144 , version 1 (04-11-2015)
  • HAL Id : hal-01224144 , version 1
Tushant Jha, Walid Belkhir, Yannick Chevalier, Michael Rusinowitch. Expressive Equivalence and Succinctness of Parametrized Automata with respect to Finite Memory Automata. FOR-MOVES 2015: FORmal MOdeling and VErification of Service-based systems, Nov 2015, Goa, India. ⟨hal-01224144⟩
253 Consultations
503 Téléchargements
