Advanced diagnostics and prognostics testbed, Proceedings of the 18th International Workshop on Principles of Diagnosis, pp.178-185, 2007. ,
Functional and teleological knowledge in the multimodeling approach for reasoning about physical systems: a case study in diagnosis, IEEE Transactions on Systems, Man, and Cybernetics, vol.23, issue.6, pp.1718-1751, 1993. ,
DOI : 10.1109/21.257765
Hierarchical modelling and diagnosis for embedded systems. 17th International Workshop on Principles of Diagnosis DX'06, pp.235-242, 2006. ,
Algebraic approach for model decomposition: Application to fault detection and isolation in discrete-event systems, International Journal of Applied Mathematics and Computer Science, vol.21, issue.1, pp.109-125, 2011. ,
DOI : 10.2478/v10006-011-0008-z
Diagnostic of the avionic equipment based on dynamic fault tree, Proceedings of the IFAC-CEA conference, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00184968
Incorporating Uncertainty in Diagnostic Analysis of Mechanical Systems, pp.315-325, 2005. ,
Fault diagnosis and failure prognosis for engineering systems: A global perspective, 2009 IEEE International Conference on Automation Science and Engineering, pp.108-115, 2009. ,
DOI : 10.1109/COASE.2009.5234094
Alain Griffault, and Gérald Point. Model-based diagnosis for avionics systems using minimal cuts, DX 2011 22nd International Workshop on Principles of Diagnosis, pp.138-145, 2011. ,
Optimal input design for a nonlinear dynamical uncertain aerospace system, IFAC Proceedings Volumes, vol.46, issue.23, 2013. ,
DOI : 10.3182/20130904-3-FR-2041.00060
Model-based Reasoning: Troubleshooting, pp.297-346, 1988. ,
DOI : 10.1016/B978-0-934613-67-5.50012-5
URL : http://dspace.mit.edu/handle/1721.1/6491#files-area
Characterizing diagnoses and systems, Artificial Intelligence, vol.56, issue.2-3, pp.197-222, 1992. ,
DOI : 10.1016/0004-3702(92)90027-U
Meta-Diagnosis for a Special Class of Cyber-Physical Systems: The Avionics Test Benches ,
DOI : 10.1007/978-3-319-19066-2_61
Methodology and Application of Meta-Diagnosis on Avionics Test Benches (Accepted), Proceedings of 26th International Workshop on Principles of Diagnosis (DX-15), p.2015 ,
