A physically accurate reflectance model combining reflection and diffraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Un modèle de réflectance combinant diffraction et réflexion
Reflectance properties express how objects in a virtual scene interact with light. They control the appearance of the object: whether it looks shiny or not, it has a metallic or plastic appearance. The reflectance model (BRDF) is essential for photorealistic pictures. Measured reflectance provide high realism, at the expense of memory cost. Parametric models are compact, but it is difficult to find the right parameters from measured reflectance. In this research report, we show that two different physical phenomena are present in measured reflectance: reflection and diffraction. Taking both into account, we present a reflectance model that is compact and a very good approximation of measured reflectance. Designers can act on model parameters, related to surface properties, to create new materials.
RR-8807 (1).pdf (11.97 Mo) Télécharger le fichier
patch_brdf.zip (465.52 Ko) Télécharger le fichier
supplemental.pdf (271.75 Mo) Télécharger le fichier
Format : Figure, Image
hal-01224702 , version 1 (05-11-2015)
  • HAL Id : hal-01224702 , version 1
Nicolas Holzschuch, Romain Pacanowski. A physically accurate reflectance model combining reflection and diffraction. [Research Report] RR-8807, INRIA. 2015, pp.24. ⟨hal-01224702⟩
3188 Consultations
2884 Téléchargements
