Extracting Skeletal Curves from 3D Scattered Data
We introduce a method for extracting skeletal curves from an unorganized collection of scattered data points lying on a surface. These curves may have a tree like structure to capture branching shapes such as blood vessels. The skeletal curves can be used for different applications ranging from surface reconstruction to object recognition.
