Journal articles
The Multidimensional Knapsack Problem: Structure and Algorithms
Abstract : We study the multidimensional knapsack problem, present some theoretical and empirical results about its structure, and evaluate different Integer Linear Programming (ILP) based, metaheuristic, and collaborative approaches for it. We start by considering the distances between optimal solutions to the LP-relaxation and the original problem and then introduce a new core concept for the MKP, which we study extensively. The empirical analysis is then used to develop new concepts for solving the MKP using ILP-based and memetic algorithms. Different collaborative combinations of the presented methods are discussed and evaluated. Further computational experiments with longer run-times are also performed in order to compare the solutions of our approaches to the best known solutions of another so far leading approach for common MKP benchmark instances. The extensive computational experiments show the effectiveness of the proposed methods, which yield highly competitive results in significantly shorter run-times than previously described approaches.
Document type :
Journal articles
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01224914
Contributor : Jakob Puchinger Connect in order to contact the contributor
Submitted on : Thursday, November 5, 2015 - 11:59:26 AM
Last modification on : Thursday, January 6, 2022 - 12:28:03 PM
Long-term archiving on: : Saturday, February 6, 2016 - 11:18:49 AM
File
puchinger-07.pdf
Identifiers
Collections
Citation
Jakob Puchinger, Günther R. Raidl, Ulrich Pferschy. The Multidimensional Knapsack Problem: Structure and Algorithms. INFORMS Journal on Computing, Institute for Operations Research and the Management Sciences (INFORMS), 2010, 22 (2), pp.250 - 265. ⟨10.1287/ijoc.1090.0344⟩. ⟨hal-01224914⟩
Share
Metrics
Record views
124
Files downloads
6095
