Dimension-driven Geometry in CAD : A Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1989
In this paper we present different approaches occurring in recent literature to solve the problem of parametrizing mechanical designs by dimensions. We describe the approaches showing their advantages and their drawbacks. We conclude that the reviewed approaches each have different strengths. It is proposed that a method should be investigated which would combine valuable properties of the AI approaches along with the benefits of the global approach.
surveyCAD.pdf (121.67 Ko) Télécharger le fichier
hal-01224960 , version 1 (05-11-2015)
Dieter Roller, François Schonek, Anne Verroust. Dimension-driven Geometry in CAD : A Survey. Theory and Practice of Geometric Modeling, , 1989, ⟨10.1007/978-3-642-61542-9_32⟩. ⟨hal-01224960⟩
125 Consultations
143 Téléchargements
