P. R. Atherton, A scan-line hidden surface removal procedure for constructive solid geometry, ACM SIGGRAPH Computer Graphics, vol.17, issue.3, pp.73-82, 1983.
DOI : 10.1145/964967.801135
P. R. Atherton and K. Weiler, Hidden Surface Removal using Polygon Area Sorting, Computer Graphics, vol.11, issue.2, pp.214-222, 1977.
. Bro and W. F. Bronsvoort, Techniques for reducing Boolean evaluation time in CSG scan-line algorithms, Computer Aided Design, vol.18, issue.10, pp.533-538, 1986.
W. F. Bjv-]-bronsvoort, F. W. Jansen, and J. J. Van-wijk, Two methods for improving the efficiency of ray casting in solid modelling, Computer-Aided Design, vol.16, issue.1, pp.51-55, 1984.
DOI : 10.1016/S0010-4485(84)80008-1
G. A. Crocker, Invisibility coherence for faster scan-line hidden surface algorithms, ACM SIGGRAPH Computer Graphics, vol.18, issue.3, pp.95-102, 1984.
DOI : 10.1145/964965.808584
D. P. Greenberg, G. Hooper, and H. Weghorst, Improved Computational Methods for Ray Tracing, ACM Transactions on Graphics, vol.3, issue.1, pp.52-69, 1984.
J. F. Hughes, D. H. Laidlaw, and W. B. Trumbore, Constructive Solid Geometry for Polyhedral Objects, Computer Graphics, vol.20, issue.4, pp.161-169, 1986.
F. W. Jansen, A CSG List Priority Hidden Surface Algorithm, Eurograph- ics'85 proceedings, pp.51-62
. Kaj and J. T. Kajiya, Tutorial on Ray Tracing
N. Ohm-]-okino, Y. Kakazu, and M. Morimoto, Extended Depth-Buffer Algorithms for Hidden-Surface Visualization, IEEE Computer Graphics and Applications, pp.79-88, 1984.
. Rro, A. G. Requicha, and J. Rossignac, Depth-buffering Display Techniques for Constructive Solid Geometry, IEEE Computer Graphics and Applications, pp.29-39, 1986.
. Rvo, A. A. Requicha, and H. B. Voelcker, Boolean Operations in Solid Modeling: Boundary evaluation and Merging Algorithms, IEEE Computer Graphics and Applications, pp.30-34, 1985.
. Rot and S. D. Roth, Ray Casting for Modelling Solids, Computer Graphics and Image Processing, issue.18, pp.109-144, 1982.
A. Verroust, A CSG Visualization Algorithm using Polygon Clipping, Rapport INRIA, issue.461, 1985.
