Book sections
A Lagrangian Decomposition/Evolutionary Algorithm Hybrid for the Knapsack Constrained Maximum Spanning Tree Problem
Abstract : We present a Lagrangian decomposition approach for the Knapsack Constrained Maximum Spanning Tree problem yielding upper bounds as well as heuristic solutions. This method is further combined with an evolutionary algorithm to a sequential hybrid approach. Thorough experimental investigations, including a comparison to a previously suggested simpler Lagrangian relaxation based method, document the advantages of our approach. Most of the upper bounds derived by Lagrangian decomposition are optimal, and when additionally applying local search (LS) and combining it with the evolutionary algorithm, large and supposedly hard instances can be either solved to provable optimality or with a very small remaining gap in reasonable time.
Document type :
Book sections
Complete list of metadata
https://hal.inria.fr/hal-01226565
Contributor : Jakob Puchinger Connect in order to contact the contributor
Submitted on : Monday, November 9, 2015 - 6:35:35 PM
Last modification on : Wednesday, October 13, 2021 - 7:58:04 PM
Links full text
Identifiers
Citation
Sandro Pirkwieser, Günther R. Raidl, Jakob Puchinger. A Lagrangian Decomposition/Evolutionary Algorithm Hybrid for the Knapsack Constrained Maximum Spanning Tree Problem. Recent Advances in Evolutionary Computation for Combinatorial Optimization, 2008, 978-3-540-70806-3. ⟨10.1007/978-3-540-70807-0_5⟩. ⟨hal-01226565⟩
Share
Metrics
Record views
21
