Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Recursive state estimation for a set-membership description of uncertainty. Automatic Control, IEEE Transactions on, vol.16, issue.2, pp.117-128, 1971. ,
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
State estimation for dynamic systems, Boca Raton, 1994. ,
Control of nonlinear dynamical systems: methods and applications, 2008. ,
DOI : 10.1007/978-3-540-70784-4
Introduction to calculus and analysis, 2000. ,
Output linear controller for a class of nonlinear systems using the invariant ellipsoid technique, 2009 American Control Conference, pp.1160-1165, 2009. ,
DOI : 10.1109/ACC.2009.5160434
Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
DOI : 10.1137/0324047
Neural networks and learning machines, 2009. ,
Nonlinear control systems, 1995. ,
A GENERAL APPROACH TO THE SOLUTION OF THE BOUNDED CONTROL SYNTHESIS PROBLEM IN A CONTROLLABILITY PROBLEM, Mathematics of the USSR-Sbornik, vol.37, issue.4, pp.582-606, 1979. ,
DOI : 10.1070/SM1980v037n04ABEH002094
Controllability function method. M.Izhevsk: NIC Regularnaya i Haoticheskaya Dinamika, Computer Researches Institute, 2007. ,
Control and observation under uncertainty (in russian), 1977. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
Robust control for a class of continuoustime dynamical systems with sample-data outputs, Electrical engineering, computing science and automatic control,cce 6th international conference on, pp.1-7, 2009. ,
Finite time stability and stabilization of a class of continuous systems, Journal of Mathematical Analysis and Applications, vol.323, issue.2, pp.1430-1443, 2006. ,
DOI : 10.1016/j.jmaa.2005.11.046
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Ellipsoidal parameter or state estimation under model uncertainty, Automatica, vol.40, issue.7, pp.1171-1179, 2004. ,
DOI : 10.1016/j.automatica.2004.02.014
Suppression of bounded exogenous disturbances: Output feedback. Automation and Remote Control, pp.801-818, 2008. ,
Finite-time Stabilization Using Implicit Lyapunov Function Technique, 9th symposium on nonlinear control systems, pp.140-145, 2013. ,
DOI : 10.3182/20130904-3-FR-2041.00043
URL : https://hal.archives-ouvertes.fr/hal-00844386
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Advanced mathematical tools for automatic control engineers: Deterministic techniques, 2008. ,
Practical output feedback stabilisation for a class of continuous-time dynamic systems under sample-data outputs, International Journal of Control, vol.36, issue.8, pp.1408-1416, 2011. ,
DOI : 10.1016/j.automatica.2008.07.013
Attractive ellipsoids in robust control, 2014. ,
DOI : 10.1007/978-3-319-09210-2
URL : https://hal.archives-ouvertes.fr/hal-01088632
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Recursive state estimation: Unknown but bounded errors and system inputs, IEEE Transactions on Automatic Control, vol.13, issue.1, pp.22-28, 1968. ,
DOI : 10.1109/TAC.1968.1098790
Sliding mode control and observation, 2014. ,
DOI : 10.1007/978-0-8176-4893-0
Ellipsoidal Set-Theoretic Control Synthesis, Journal of Dynamic Systems, Measurement, and Control, vol.104, issue.4, pp.331-336, 1981. ,
DOI : 10.1115/1.3139718
Sliding mode control in electro-mechanical systems Methods of a.m. Lyapunov and their applications, 1964. ,
