Computing floating-point logarithms with fixed-point operations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Elementary functions from the mathematical library input and output floating-point numbers. However it is possible to implement them purely using integer/fixed-point arithmetic. This option was not attractive between 1985 and 2005, because mainstream processor hardware supported 64-bit floating-point, but only 32-bit integers. Besides, conversions between floating-point and integer were costly. This has changed in recent years, in particular with the generalization of native 64-bit integer support. The purpose of this article is therefore to reevaluate the relevance of computing floating-point functions in fixed-point. For this, several variants of the double-precision logarithm function are implemented and evaluated. Formulating the problem as a fixed-point one is easy after the range has been (classically) reduced. Then, 64-bit integers provide slightly more accuracy than 53-bit mantissa, which helps speed up the evaluation. Finally, multi-word arithmetic, critical for accurate implementations, is much faster in fixed-point, and natively supported by recent compilers. Novel techniques of argument reduction and rounding test are introduced in this context. Thanks to all this, a purely integer implementation of the correctly rounded double-precision logarithm outperforms the previous state of the art, with the worst-case execution time reduced by a factor 5. This work also introduces variants of the logarithm that input a floating-point number and output the result in fixed-point. These are shown to be both more accurate and more efficient than the traditional floating-point functions for some applications.
2015-FixFloat.pdf (269.68 Ko) Télécharger le fichier
hal-01227877 , version 1 (12-11-2015)
  • HAL Id : hal-01227877 , version 1
Julien Le Maire, Nicolas Brunie, Florent de Dinechin, Jean-Michel Muller. Computing floating-point logarithms with fixed-point operations. 23rd IEEE Symposium on Computer Arithmetic, IEEE, Jul 2016, Santa Clara, United States. ⟨hal-01227877⟩
495 Consultations
7560 Téléchargements
