The Peculiar Landscape of Repetitive Sequences in the Olive (Olea europaea L.) Genome, Genome Biology and Evolution, vol.6, issue.4, pp.776-91, 2014. ,
DOI : 10.1093/gbe/evu058
RepeatExplorer: a Galaxy-based web server for genome-wide characterization of eukaryotic repetitive elements from next-generation sequence reads, Bioinformatics, vol.29, issue.6, pp.79279-79282, 2013. ,
DOI : 10.1093/bioinformatics/btt054
Sequence-specific error profile of Illumina sequencers, Nucleic Acids Research, vol.39, issue.13, 2011. ,
DOI : 10.1093/nar/gkr344
Roche 454 sequencing technologies on the same microbial community DNA sample, Direct comparisons of Illumina vs, 2012. ,
Repbase Update, a database of eukaryotic repetitive elements, Repbase Update, pp.462-467, 2005. ,
DOI : 10.1159/000084979
Discovering and detecting transposable elements in genome sequences, Briefings in Bioinformatics, vol.8, issue.6, pp.382-392, 2007. ,
DOI : 10.1093/bib/bbm048
A new method to compute K-mer frequencies and its application to annotate large repetitive plant genomes, BMC Genomics, vol.9, issue.1, p.517, 2008. ,
DOI : 10.1186/1471-2164-9-517
REPuter: the manifold applications of repeat analysis on a genomic scale, Nucleic Acids Research, vol.29, issue.22, pp.4633-4675, 2001. ,
DOI : 10.1093/nar/29.22.4633
A clustering method for repeat analysis in DNA sequences, Genome Biol, vol.8, issue.2, p.27, 2001. ,
WindowMasker: window-based masker for sequenced genomes, Bioinformatics, vol.22, issue.2, pp.134-175, 2006. ,
DOI : 10.1093/bioinformatics/bti774
A fast, lock-free approach for efficient parallel counting of occurrences of k-mers, Bioinformatics, vol.27, issue.6, pp.764-770, 2011. ,
DOI : 10.1093/bioinformatics/btr011
Identification of repeat structure in large genomes using repeat probability clouds, Analytical Biochemistry, vol.380, issue.1, pp.77-83, 2008. ,
DOI : 10.1016/j.ab.2008.05.015
Repseek, a tool to retrieve approximate repeats from large DNA sequences, Bioinformatics, vol.23, issue.1, pp.119-140, 2007. ,
DOI : 10.1093/bioinformatics/btl519
Estimating the probability of approximate matches, Lecture Notes in Computer Science, vol.1264, pp.52-64, 1997. ,
DOI : 10.1007/3-540-63220-4_49
Velvet: Algorithms for de novo short read assembly using de Bruijn graphs, Genome Research, vol.18, issue.5, pp.821-829, 2008. ,
DOI : 10.1101/gr.074492.107
Basic local alignment search tool, Journal of Molecular Biology, vol.215, issue.3, pp.403-413, 1990. ,
DOI : 10.1016/S0022-2836(05)80360-2
PILER: identification and classification of genomic repeats, Bioinformatics, vol.21, issue.Suppl 1, p.18, 2005. ,
DOI : 10.1093/bioinformatics/bti1003
Discovery and assembly of repeat family pseudomolecules from sparse genomic sequence data using the Assisted Automated Assembler of Repeat Families (AAARF) algorithm, BMC Bioinformatics, vol.9, issue.1, pp.235-245, 2008. ,
DOI : 10.1186/1471-2105-9-235
NCBI BLAST: a better web interface, Nucleic Acids Research, vol.36, issue.Web Server, pp.5-9, 2008. ,
DOI : 10.1093/nar/gkn201
Improving the accuracy of PSI-BLAST protein database searches with composition-based statistics and other refinements, Nucleic Acids Research, vol.29, issue.14, pp.2994-3005, 2001. ,
DOI : 10.1093/nar/29.14.2994
RepeatMasker Open-3.0. [En ligne] 1996-2010 ,
An automated homology-based approach for identifying transposable elements, BMC Bioinformatics, vol.12, issue.1, p.130, 2011. ,
DOI : 10.1093/nar/gkn857
The Use of RelocaTE and Unassembled Short Reads to Produce High-Resolution Snapshots of Transposable Element Generated Diversity in Rice, G3: Genes|Genomes|Genetics, vol.3, issue.6, pp.949-957, 2013. ,
DOI : 10.1534/g3.112.005348
TARGeT: a web-based pipeline for retrieving and characterizing gene and transposable element families from genomic sequences, Nucleic Acids Research, vol.37, issue.11, p.78, 2009. ,
DOI : 10.1093/nar/gkp295
MUSCLE: multiple sequence alignment with high accuracy and high throughput, Nucleic Acids Research, vol.32, issue.5, pp.1792-1797, 2004. ,
DOI : 10.1093/nar/gkh340
URL : http://doi.org/10.1093/nar/gkh340
Computing Large Minimum-Evolution Trees with Profiles instead of a Distance Matrix ,
FastTree: Computing Large Minimum Evolution Trees with Profiles instead of a Distance Matrix, Molecular Biology and Evolution, vol.26, issue.7, pp.1641-1650, 2009. ,
DOI : 10.1093/molbev/msp077
CAP3: A DNA Sequence Assembly Program, Genome Research, vol.9, issue.9, pp.868-77, 1999. ,
DOI : 10.1101/gr.9.9.868
???One code to find them all???: a perl tool to conveniently parse RepeatMasker output files, Mobile DNA, vol.5, issue.1, pp.10-1186, 2014. ,
DOI : 10.1016/j.tig.2007.02.006
RetroSeq: transposable element discovery from next-generation sequencing data, Bioinformatics, vol.29, issue.3, pp.389-390, 2012. ,
DOI : 10.1093/bioinformatics/bts697
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3562067
HMMER web server: interactive sequence similarity searching, Nucleic Acids Research, vol.39, issue.suppl, pp.29-37, 2011. ,
DOI : 10.1093/nar/gkr367
SMOTIF: efficient structured pattern and profile motif search, Algorithms for Molecular Biology, vol.1, issue.1, p.22, 2006. ,
DOI : 10.1186/1748-7188-1-22
Suffix-tree analyser (STAN): looking for nucleotidic and peptidic patterns in chromosomes, Bioinformatics, vol.21, issue.24, pp.4408-4418, 2005. ,
DOI : 10.1093/bioinformatics/bti710
Considering Transposable Element Diversification in De Novo Annotation Approaches, PLoS ONE, vol.25, issue.3, p.16526, 2011. ,
DOI : 10.1371/journal.pone.0016526.s021
URL : https://hal.archives-ouvertes.fr/hal-00568705
A Versatile. ; High Performance Pipeline for the Automated Annotation of Plant Genomes ,
RISCI - Repeat Induced Sequence Changes Identifier: a comprehensive, comparative genomics-based, in silico subtractive hybridization pipeline to identify repeat induced sequence changes in closely related genomes, BMC Bioinformatics, vol.11, issue.1, pp.1471-2105, 1186. ,
DOI : 10.1186/1471-2105-11-609
LTR_STRUC: a novel search and identification program for LTR retrotransposons, Bioinformatics, vol.19, issue.3, pp.362-367, 2003. ,
DOI : 10.1093/bioinformatics/btf878
EFFICIENT ALGORITHMS AND SOFTWARE FOR DETECTION OF FULL-LENGTH LTR RETROTRANSPOSONS, Journal of Bioinformatics and Computational Biology, vol.04, issue.02, pp.197-216, 2006. ,
DOI : 10.1142/S021972000600203X
LTR_FINDER: an efficient tool for the prediction of full-length LTR retrotransposons, Nucleic Acids Research, vol.35, issue.Web Server, pp.265-268, 2007. ,
DOI : 10.1093/nar/gkm286
De novo identification of LTR retrotransposons in eukaryotic genomes, BMC Genomics, vol.8, issue.1, p.90, 2007. ,
DOI : 10.1186/1471-2164-8-90
TEnest: Automated Chronological Annotation and Visualization of Nested Plant Transposable Elements, PLANT PHYSIOLOGY, vol.146, issue.1, pp.45-59, 2008. ,
DOI : 10.1104/pp.107.110353
De novo identification of repeat families in large genomes, Bioinformatics, vol.21, issue.Suppl 1, pp.351-359, 2005. ,
DOI : 10.1093/bioinformatics/bti1018
Detection of New Transposable Element Families in Drosophila melanogaster and Anopheles gambiae Genomes, Journal of Molecular Evolution, vol.57, issue.0, pp.50-59, 2003. ,
DOI : 10.1007/s00239-003-0007-2
On global sequence alignment, Bioinformatics, vol.10, issue.3, pp.227-235, 1994. ,
DOI : 10.1093/bioinformatics/10.3.227
Recent developments in the MAFFT multiple sequence alignment program, Briefings in Bioinformatics, vol.9, issue.4, pp.286-298, 2008. ,
DOI : 10.1093/bib/bbn013
mreps: efficient and flexible detection of tandem repeats in DNA, Nucleic Acids Research, vol.31, issue.13, pp.3672-3678, 2003. ,
DOI : 10.1093/nar/gkg617
URL : https://hal.archives-ouvertes.fr/inria-00099597
LTRharvest, an efficient and flexible software for de novo detection of LTR retrotransposons, BMC Bioinformatics, vol.9, issue.1, p.18, 2008. ,
DOI : 10.1186/1471-2105-9-18
GenomeTools: A Comprehensive Software Library for Efficient Processing of Structured Genome Annotations, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.10, issue.3, pp.645-656, 2013. ,
DOI : 10.1109/TCBB.2013.68
MASiVE: Mapping and Analysis of SireVirus Elements in plant genome sequences, Bioinformatics, vol.26, issue.19, pp.2452-2454, 2010. ,
DOI : 10.1093/bioinformatics/btq454
Vmatch: large scale sequence analysis software, 2011. ,
computational identification and classification of autonomous non-LTR retrotransposons in eukaryotic genomes, Nucl. Acids Res, vol.21, issue.37, p.143, 2009. ,
RTAnalyzer: a web application for finding new retrotransposons and detecting L1 retrotransposition signatures, Nucleic Acids Research, vol.35, issue.Web Server, pp.269-274, 2007. ,
DOI : 10.1093/nar/gkm313
Genome-wide Analysis of the Emigrant Family of MITEs of Arabidopsis thaliana, Molecular Biology and Evolution, vol.19, issue.12, pp.2285-93, 2002. ,
DOI : 10.1093/oxfordjournals.molbev.a004052
A fast bit-vector algorithm for approximate string matching based on dynamic programming, Ninth Combinatorial Pattern Matching Conference, vol.1448, pp.1-13, 1998. ,
DOI : 10.1007/BFb0030777
Inverted Repeat Structure of the Human Genome: The X-Chromosome Contains a Preponderance of Large, Highly Homologous Inverted Repeats That Contain Testes Genes, Genome Research, vol.14, issue.10a, pp.1861-1870, 2004. ,
DOI : 10.1101/gr.2542904
MUST: A system for identification of miniature inverted-repeat transposable elements and applications to Anabaena variabilis and Haloquadratum walsbyi, Gene, vol.436, issue.1-2, pp.1-7, 2009. ,
DOI : 10.1016/j.gene.2009.01.019
MITE-Hunter: a program for discovering miniature inverted-repeat transposable elements from genomic sequences, Nucleic Acids Research, vol.38, issue.22, p.199, 2010. ,
DOI : 10.1093/nar/gkq862
Graph Clustering Via a Discrete Uncoupling Process, SIAM Journal on Matrix Analysis and Applications, vol.30, issue.1, pp.121-141, 2008. ,
DOI : 10.1137/040608635
Structure-based discovery and description of plant and animal Helitrons, Proceedings of the National Academy of Sciences, vol.106, issue.31, pp.12832-12839, 2009. ,
DOI : 10.1073/pnas.0905563106
DINAMelt web server for nucleic acid melting prediction, Nucleic Acids Research, vol.33, issue.Web Server, pp.577-581, 2005. ,
DOI : 10.1093/nar/gki591
Handbook of exact string matching algorithms. s.l. : King's College publications, 2004. ,
Handbook of Computational Molecular Biology. [éd.] S. Aluru. s.l. : Chapman & Hall/CRC Computer and Information Science Series, 2006. ,
Compressed suffix tree a basis for genome-scale sequence analysis, Bioinformatics, vol.23, issue.5, pp.629-659, 2007. ,
DOI : 10.1093/bioinformatics/btl681
Compressed Suffix Tree. [En ligne] 2013 ,
Suffix Arrays: A New Method for On-Line String Searches, SIAM Journal on Computing, vol.22, issue.5, pp.935-948, 1993. ,
DOI : 10.1137/0222058
A bioinformatician's guide to the forefront of suffix array construction algorithms, Briefings in Bioinformatics, vol.15, issue.2 ,
DOI : 10.1093/bib/bbt081
Efficient repeat finding in sets of strings via suffix arrays, Discrete Mathematics & Theoretical Computer Science, vol.2, issue.15, pp.59-70, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00980753
A block sorting lossless data compression algorithm. Digital Equipment Corporation. Palo Alto : s.n, 1994. ,
Compressed Indexes and their Testbeds. [En ligne] sept, 2005. ,
RAPSearch2: a fast and memory-efficient protein similarity search tool for next-generation sequencing data, Bioinformatics, vol.28, issue.1, pp.125-126, 2012. ,
DOI : 10.1093/bioinformatics/btr595
14, s.l. : Oxford Pub, Bioinformatics, vol.25, pp.1754-1760, 2009. ,
YASS: enhancing the sensitivity of DNA similarity search, Nucleic Acids Research, vol.33, issue.Web Server, pp.540-543, 2005. ,
DOI : 10.1093/nar/gki478
URL : https://hal.archives-ouvertes.fr/inria-00100004
Sequence analysis of two alleles reveals that intra-and intergenic recombination played a role in the evolution of the radish fertility restorer (Rfo), BMC Plant Biol, vol.35, issue.10, 2010. ,
NextGenMap: fast and accurate read mapping in highly polymorphic genomes, Bioinformatics, vol.29, issue.21, pp.2790-2791, 2013. ,
DOI : 10.1093/bioinformatics/btt468
De novo assembly and genotyping of variants using colored de Bruijn graphs, Nature Genetics, vol.44, issue.2, pp.226-232, 2012. ,
DOI : 10.1016/0198-8859(91)90078-N
RepARK--de novo creation of repeat libraries from whole-genome NGS reads, Nucleic Acids Research, vol.42, issue.9, 2014. ,
DOI : 10.1093/nar/gku210
Automated generation of heuristics for biological sequence comparison, BMC Bioinformatics, vol.6, issue.1, pp.10-1186, 2005. ,
Repeatability of published microarray gene expression analyses, Nature Genetics, vol.4, issue.2, pp.149-155, 2009. ,
DOI : 10.1097/EDE.0b013e31818131e7
The Taverna workflow suite: designing and executing workflows of Web Services on the desktop, web or in the cloud, Nucleic Acids Research, vol.41, issue.W1, pp.557-561 ,
DOI : 10.1093/nar/gkt328
ScanProsite: detection of PROSITE signature matches and ProRule-associated functional and structural residues in proteins, Nucleic Acids Research, vol.34, issue.Web Server, pp.362-365, 2006. ,
DOI : 10.1093/nar/gkl124
A Composite Method Based on Formal Grammar and DNA Structural Features in Detecting Human Polymerase II Promoter Region, PLoS ONE, vol.24, issue.6, 2013. ,
DOI : 10.1371/journal.pone.0054843.t006
RNAMotif: A new RNA secondary structure definition and discovery algorithm, Nucl Acids Res, vol.22, issue.29, pp.4724-4735, 2001. ,
Locomotif: from graphical motif description to RNA motif search, Bioinformatics, vol.23, issue.13, pp.392-400, 2007. ,
DOI : 10.1093/bioinformatics/btm179
Structator: fast index-based search for RNA sequence-structure patterns, BMC Bioinformatics, vol.12, issue.1, pp.10-1186, 2011. ,
DOI : 10.1093/bioinformatics/btp250
Replacing suffix trees with enhanced suffix arrays, Journal of Discrete Algorithms, vol.2, issue.1, pp.53-86, 2004. ,
DOI : 10.1016/S1570-8667(03)00065-0
MIPS PlantsDB: a database framework for comparative plant genome research, Database issue), pp.1144-51, 2013. ,
DOI : 10.1093/nar/gks1153
Pattern Search. [En ligne, 2007. ,
Biogrep: a multi?threaded pattern matcher for large pattern sets. kljensen/biogrep · GitHub. [En ligne, 2002. ,
En ligne] jul, 2010. ,
Application to the Modelling of -1 Ribosomal Frameshift events, Expressive Pattern Matching with Logol ,
MASiVEdb: the Sirevirus Plant Retrotransposon Database, BMC Genomics, vol.13, issue.1, 2012. ,
DOI : 10.1093/molbev/msh057
P-MITE: a database for plant miniature inverted-repeat transposable elements, Database issue), pp.1176-81, 2013. ,
DOI : 10.1093/nar/gkt1000
Recovery of ancestral sequences for transposable elements from the unassembled reads of a whole genome shotgun, et al. PLoS Comput Biol, vol.4, issue.1, p.43, 2005. ,
The TIGR Plant Repeat Databases: a collective resource for the identification of repetitive sequences in plants, Nucleic Acids Research, vol.32, issue.90001, pp.360-363, 2004. ,
DOI : 10.1093/nar/gkh099
RJPrimers: unique transposable element insertion junction discovery and PCR primer design for marker development, Nucleic Acids Research, vol.38, issue.Web Server, pp.313-333, 2010. ,
DOI : 10.1093/nar/gkq425
TIF): a novel program for detection of de novo transpositions of transposable elements, BMC Bioinformatics, vol.15, pp.10-1186 ,
