Fast hierarchical algorithms for generating Gaussian random fields
Algorithmes hiérarchiques rapides pour la génération de champs aléatoires Gaussiens.
Low-rank approximation (LRA) techniques have become crucial tools in scientific computing in order to reduce the cost of storing matrices and compute usual matrix operations. Since standard techniques like the SVD do not scale well with the problem size N, there has been recently a growing interest for alternative methods like randomized LRAs. These methods are usually cheap, easy to implement and optimize, since they involve only very basic operations like Matrix Vector Products (MVPs) or orthogonalizations. More precisely, randomization allows for reducing the cubic cost required to perform a standard matrix factorization to the quadratic cost required to apply a few MVPs, namely O(r × N^2) operations where r is the numerical rank of the matrix. First of all, we present a new efficient algorithm for performing MVPs in O(N) operations called the Uniform FMM (ufmm). It is based on a hierarchical (data sparse) representation of a kernel matrix combined with polynomial interpolation of the kernel on equispaced grids. The latter feature allows for FFT-acceleration and consequently reduce both running time and memory footprint but has implications on accuracy and stability. Then, the ufmm is used to speed-up the MVPs involved in the randomized SVD, thus reducing its cost to O(r^2 × N) and exhibiting very competitive performance when the distribution of points is large and highly heterogeneous. Finally, we make use of this algorithm to efficiently generate spatially correlated multivariate Gaussian random variables.
Les approximations de rang faible (LRA) sont devenus des outils fondamentaux en calcul scientifique en vue de réduire les coûts liés au stockage et aux opérations matricielles. Le coût des méthodes standards comme la SVD croît très rapidement avec la taille du problème N, c'est pourquoi des méthodes alternatives comme les approches aléatoires (i.e. basées sur la projection ou la sélection de colonnes/l'échantillonnage aléatoire) se popularisent. Ces méthodes sont en général peu coûteuses et facile à implémenter et optimiser, car elles ne mettent en oeuvre que des opérations matricielles simples comme des produits ou des orthogonalisations. Plus précisemment, les LRA aléatoires permettent de réduire le coût cubique en N des méthodes standards de factorisation au coût quadratique nécessaire à la réalisation de quelques produits matrices vecteurs, i.e., O(r × N^2) opérations où r est le rang numérique de la matrice. Dans un premier temps, nous présentons un algorithme efficace pour réaliser des MVPs en O(N) opérations, que nous appelons Uniform FMM (ufmm). Il est basé sur la combinaison d'une représentation hiérachique d'une matrice noyau et l'interpolation polynomiale du noyau associé sur une grille régulière (uniforme). Cette dernière propriété permet une accélération par FFT réduisant ainsi le temps de calcul et la consommation mémoire mais a des répercussions sur la précision et la stabilité de l'algorithme. Ensuite, la ufmm est utilisée pour accélerer les MVPs intervenants dans la SVD aléatoire (i.e., SVD par projection aléatoire) diminuant son coût asymptotique à O(r^2 × N). La méthode est particulièrement compétitive pour des distributions de points hétérogènes. Enfin, nous utilisons cet algorithme pour générer des champs de variables Gaussiens de manière efficace.
