A Monitoring System for Runtime Adaptations of Streaming Applications
Streaming languages are adequate for expressing many applications quite naturally and have been proven to be a good approach for taking advantage of the intrinsic parallelism of modern CPU architectures. While numerous works focus on improving the throughput of streaming programs, we rather focus on satisfying quality-of-service requirements of streaming applications executed alongside non-streaming processes. We monitor synchronous dataflow (SDF) programs at runtime both at the application and system levels in order to identify violations of quality-of-service requirements. Our monitoring requires the programmer to provide the expected throughput of its application (e.g 25 frames per second for a video decoder), then takes full benefit from the compilation of the SDF graph to detect bottlenecks in this graph and identify causes among processor or memory overloading. It can then be used to perform dynamic adaptations of the applications in order to optimize the use of computing and memory resources.
Systèmes embarqués
