Random sampling of bandlimited signals on graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We study the problem of sampling k-bandlimited signals on graphs. We propose two sampling strategies that consist in selecting a small subset of nodes at random. The first strategy is non-adaptive, i.e., independent of the graph structure, and its performance depends on a parameter called the graph coherence. On the contrary, the second strategy is adaptive but yields optimal results. Indeed, no more than O(k log(k)) measurements are sufficient to ensure an accurate and stable recovery of all k-bandlimited signals. This second strategy is based on a careful choice of the sampling distribution, which can be estimated quickly. Then, we propose a computationally efficient decoder to reconstruct k-bandlimited signals from their samples. We prove that it yields accurate reconstructions and that it is also stable to noise. Finally, we conduct several experiments to test these techniques.
main.pdf (7.36 Mo) Télécharger le fichier
hal-01229578 , version 1 (16-11-2015)
hal-01229578 , version 2 (20-05-2016)
hal-01229578 , version 3 (27-07-2016)
  • HAL Id : hal-01229578 , version 1
Gilles Puy, Nicolas Tremblay, Rémi Gribonval, Pierre Vandergheynst. Random sampling of bandlimited signals on graphs. 2015. ⟨hal-01229578v1⟩
496 Consultations
889 Téléchargements
