Preprints, Working Papers, ...
Random sampling of bandlimited signals on graphs
Abstract : We study the problem of sampling k-bandlimited signals on graphs. We propose two sampling strategies that consist in selecting a small subset of nodes at random. The first strategy is non-adaptive, i.e., independent of the graph structure, and its performance depends on a parameter called the graph coherence. On the contrary, the second strategy is adaptive but yields optimal results. Indeed, no more than O(k log(k)) measurements are sufficient to ensure an accurate and stable recovery of all k-bandlimited signals. This second strategy is based on a careful choice of the sampling distribution, which can be estimated quickly. Then, we propose a computationally efficient decoder to reconstruct k-bandlimited signals from their samples. We prove that it yields accurate reconstructions and that it is also stable to noise. Finally, we conduct several experiments to test these techniques.
Document type :
Complete list of metadatas
https://hal.inria.fr/hal-01229578
Contributor : Gilles Puy <>
Submitted on : Friday, May 20, 2016 - 2:46:39 PM
Last modification on : Thursday, November 15, 2018 - 11:58:46 AM
File
revised_manuscript.pdf
Identifiers
  • HAL Id : hal-01229578, version 2
Citation
Gilles Puy, Nicolas Tremblay, Rémi Gribonval, Pierre Vandergheynst. Random sampling of bandlimited signals on graphs. 2015. ⟨hal-01229578v2⟩
Share
Metrics
Record views
145
Files downloads
61
