Factoring Safe Semiprimes with a Single Quantum Query - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Shor's factoring algorithm (SFA), by its ability to efficiently factor large numbers, has the potential to undermine contemporary encryption. At its heart is a process called order finding, which quantum mechanics lets us perform efficiently. SFA thus consists of a quantum order finding algorithm (QOFA), bookended by classical routines which, given the order, return the factors. But, with probability up to 1/2, these classical routines fail, and QOFA must be rerun. We modify these routines using elementary results in number theory, improving the likelihood that they return the factors. We present a new quantum factoring algorithm based on QOFA which is better than SFA at factoring safe semiprimes, an important class of numbers used in RSA encryption (and reputed to be the hardest to factor). With just one call to QOFA, our algorithm almost always factors safe semiprimes. As well as a speed-up, improving efficiency gives our algorithm other, practical advantages: unlike SFA, it does not need a randomly picked input, making it simpler to construct in the lab; and in the (unlikely) case of failure, the same circuit can be rerun, without modification. We consider generalising this result to other cases, although we do not find a simple extension, and conclude that SFA is still the best algorithm for general numbers (non safe semiprimes, in other words). Even so, we present some simple number theoretic tricks for improving SFA in this case.
hal-01229587 , version 1 (16-11-2015)
Frédéric Grosshans, Thomas Lawson, Benjamin Smith, François Morain. Factoring Safe Semiprimes with a Single Quantum Query. 2016. ⟨hal-01229587⟩
341 Consultations
0 Téléchargements
