Assessment of masonry arch railway bridges using non-destructive in-situ testing methods, Engineering Structures 31 pp 2287-2298, 2009. ,
Aptitude de la thermographie infrarouge à détecter les fissures et nids d'abielle dans le béton 12e Colloque sur la progression de la recherche québécoise sur les ouvrages, 2005. ,
Evaluation de méthodes de détection de défauts, par thermographie infrarouge active, dans des échantillons d'enrobés bitumineux, 2009. ,
Application of infrared thermography to the non-destructive testing of concrete and masonry bridges, NDT & E International, vol.36, issue.4, pp.265-275, 2003. ,
DOI : 10.1016/S0963-8695(02)00060-9
Quantitative infrared thermography in buildings, Energy and Buildings, vol.29, issue.1, pp.1-9, 1998. ,
DOI : 10.1016/S0378-7788(97)00039-X
Transport Infrastructure Surveillance and Monitoring by Electromagnetic Sensing: The ISTIMES Project, Sensors, vol.10, issue.12, pp.10620-10639, 2010. ,
DOI : 10.3390/s101210620
Development of an infrared system coupled with a weather station for real time atmospheric corrections using GPU computing: Application to bridge monitoring, Proceedings of the 2012 International Conference on Quantitative InfraRed Thermography, 2012. ,
DOI : 10.21611/qirt.2012.204
Design, conception and realisation of high energetic mechanical impacts on a civil engineering structure to evaluate sensing techniques in ISTIMES project framework, pp.2011-2014, 2011. ,
Structural monitoring via microwave tomography-enhanced GPR: the Montagnole test site, Journal of Geophysics and Engineering, vol.9, issue.4, pp.100-10710, 2012. ,
DOI : 10.1088/1742-2132/9/4/S100
Route de Bouaye -CS4, 44344 Bouguenais Cedex, France Tel: +33 240845624; Fax: +33 240845998 ,
Following positions as associate research engineer in the former Department of Studies and Research in Mechanics and Energetic Systems (DERMES) at ONERA-CERT and associate lecturer at INSA Toulouse, he joined IFSTTAR in 1997 and I4S INRIA team in 2013, His research interests include infrared thermography, heat transfer, and monitoring using imaging techniques ,
