The corrector in stochastic homogenization: optimal rates, stochastic integrability, and fluctuations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We consider uniformly elliptic coefficient fields that are randomly distributed according to a stationary ensemble of a finite range of dependence. We show that the gradient and flux (∇ϕ,a(∇ϕ+e)) of the corrector ϕ, when spatially averaged over a scale R≫1 decay like the CLT scaling R−d2. We establish this optimal rate on the level of sub-Gaussian bounds in terms of the stochastic integrability, and also establish a suboptimal rate on the level of optimal Gaussian bounds in terms of the stochastic integrability. The proof unravels and exploits the self-averaging property of the associated semi-group, which provides a natural and convenient disintegration of scales, and culminates in a propagator estimate with strong stochastic integrability. As an application, we characterize the fluctuations of the homogenization commutator, and prove sharp bounds on the spatial growth of the corrector, a quantitative two-scale expansion, and several other estimates of interest in homogenization.
hal-01230985 , version 1 (19-11-2015)
Antoine Gloria, Felix Otto. The corrector in stochastic homogenization: optimal rates, stochastic integrability, and fluctuations. 2016. ⟨hal-01230985⟩
200 Consultations
0 Téléchargements
