On-board Component Fault Detection and Isolation Using the Statistical Local Approach, Automatica, vol.34, issue.11, pp.1391-1416, 1998. ,
DOI : 10.1016/S0005-1098(98)00086-7
URL : https://hal.archives-ouvertes.fr/inria-00073437
Nonlinear model decomposition for robust fault detection and isolation using algebraic tools, Int. Jal Innovative Computing, Information and Control, vol.2, issue.6, pp.1337-1354, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00198435
Diagnosis and Fault-Tolerant Control, 2006. ,
Detection filter design for LPV systems???a geometric approach, Automatica, vol.40, issue.3, pp.511-518, 2004. ,
DOI : 10.1016/j.automatica.2003.11.003
Fault detection and isolation in nonlinear systems, Annual Reviews in Control, vol.33, issue.2, pp.113-123, 2009. ,
DOI : 10.1016/j.arcontrol.2009.09.001
Optimal filtering and robust fault diagnosis of stochastic systems with unknown disturbances, IEE Proceedings - Control Theory and Applications, vol.143, issue.1, pp.31-36, 1996. ,
DOI : 10.1049/ip-cta:19960059
Robust Model-Based Fault Diagnosis for Dynamic Systems, 1999. ,
DOI : 10.1007/978-1-4615-5149-2
Optimal stochastic fault detection filter, Automatica, vol.39, issue.3, pp.377-390, 2003. ,
DOI : 10.1016/S0005-1098(02)00245-5
A geometric approach to nonlinear fault detection and isolation, IEEE Transactions on Automatic Control, vol.45, issue.6, pp.853-865, 2001. ,
DOI : 10.1109/9.928586
Model-based Fault Diagnosis Techniques: Design Schemes, Algorithms, and Tools, 2008. ,
DOI : 10.1007/978-1-4471-4799-2
Special issue on linear parameter varying systems, International Journal of Robust and Nonlinear Control, vol.24, issue.14, pp.1925-1926, 2014. ,
DOI : 10.1002/rnc.3228
An Introduction to Probability Theory and Its Applications, of Series in Probability and Mathematical Statistics, 1966. ,
Robust residual generation for linear fault diagnosis: an algebraic setting with examples, International Journal of Control, vol.34, issue.14, pp.77-1223, 2004. ,
DOI : 10.1080/002071704200024374
Fault diagnosis in dynamic systems using analytical and knowledge-based redundancy, Automatica, vol.26, issue.3, pp.459-474, 1990. ,
DOI : 10.1016/0005-1098(90)90018-D
Fault Detection and Diagnosis in Engineering Systems, 1998. ,
Finite Memory Observers for linear time-varying systems. Part II: Observer and residual sensitivity, Journal of the Franklin Institute, vol.351, issue.5, pp.2860-2889, 2014. ,
DOI : 10.1016/j.jfranklin.2013.12.022
Finite Memory Observers for linear time-varying systems: Theory and diagnosis applications, Journal of the Franklin Institute, vol.351, issue.2, pp.785-810, 2014. ,
DOI : 10.1016/j.jfranklin.2013.08.005
A Survey of Fault Detection, Isolation, and Reconfiguration Methods, IEEE Transactions on Control Systems Technology, vol.18, issue.3, pp.636-653, 2009. ,
DOI : 10.1109/TCST.2009.2026285
Supervision, fault-detection and fault-diagnosis methods ??? An introduction, Control Engineering Practice, vol.5, issue.5, pp.639-652, 1997. ,
DOI : 10.1016/S0967-0661(97)00046-4
Fault Diagnosis Systems: An Introduction From Fault Detection To Fault Tolerance, 2005. ,
DOI : 10.1007/3-540-30368-5
Stochastic Processes and Filtering Theory, 1970. ,
Unbiased minimum-variance linear state estimation, Automatica, vol.23, issue.6, pp.775-778, 1987. ,
DOI : 10.1016/0005-1098(87)90037-9
A time domain approach to robust fault detection of linear time-varying systems, Automatica, vol.45, issue.1, pp.94-102, 2009. ,
DOI : 10.1016/j.automatica.2008.07.017
System Identification -Theory for the User, 1999. ,
An LPV Modeling and Identification Approach to Leakage Detection in High Pressure Natural Gas Transportation Networks, IEEE Transactions on Control Systems Technology, vol.19, issue.1, pp.77-92, 2011. ,
DOI : 10.1109/TCST.2010.2077293
Guest Editorial Special Issue on Applied LPV Modeling and Identification, IEEE Transactions on Control Systems Technology, vol.19, issue.1, pp.1-4, 2011. ,
DOI : 10.1109/TCST.2010.2090416
Issues of Fault Diagnosis for Dynamic Systems, 2000. ,
DOI : 10.1007/978-1-4471-3644-6
The behavioral approach to linear parametervarying systems, IEEE Trans. Automatic Control, issue.11, pp.56-2499, 2011. ,
New computational paradigms in solving fault detection and isolation problems, Proc. 8th IFAC Safeprocess, pp.983-998, 2012. ,
Statistical detection and isolation of additive faults in linear time-varying systems, Automatica, vol.50, issue.10, pp.50-2527, 2014. ,
DOI : 10.1016/j.automatica.2014.09.004
URL : https://hal.archives-ouvertes.fr/hal-01081899
