Stability of the Kalman Filter for Output Error Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Optimality and numerical efficiency are well known properties of the Kalman filter, whereas its stability property, though equally classical and important in practice, is less often mentioned in the recent literature. The stability of the Kalman filter is usually ensured by the uniform complete controllability regarding the process noise and the uniform complete observability of linear time varying systems. Such classical results cannot be applied to output error systems, in which the process noise is totally absent. It is shown in this paper that the uniform complete observability is sufficient to ensure the stability of the Kalman filter applied to time varying output error systems, regardless of the stability of the considered system itself.
Automatique
SYSID2015_OE_Kalman.pdf (226.6 Ko) Télécharger le fichier
hal-01232177 , version 1 (23-11-2015)
  • HAL Id : hal-01232177 , version 1
Boyi Ni, Qinghua Zhang. Stability of the Kalman Filter for Output Error Systems. 17th IFAC Symposium on System Identification (SYSID), Oct 2015, Beijing, China. ⟨hal-01232177⟩
170 Consultations
981 Téléchargements
