Decomposition of large-scale stochastic optimal control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue RAIRO - Operations Research Année : 2010
Pierre Carpentier
Kengy Barty
  • Fonction : Auteur
Pierre Girardeau
  • Fonction : Auteur
  • PersonId : 764150
  • IdRef : 151159351
In this paper, we present an Uzawa-based heuristic that is adapted to certain type of stochastic optimal control problems. More precisely, we consider dynamical systems that can be divided into smallscale subsystems linked through a static almost sure coupling constraint at each time step. This type of problem is common in production/ portfolio management where subsystems are, for instance, power units, and one has to supply a stochastic power demand at each time step. We outline the framework of our approach and present promising numerical results on a simplified power management problem.
hal-01232179 , version 1 (23-11-2015)
Pierre Carpentier, Kengy Barty, Pierre Girardeau. Decomposition of large-scale stochastic optimal control problems. RAIRO - Operations Research, 2010, 44, pp.167-183. ⟨10.1051/ro/2010013⟩. ⟨hal-01232179⟩
81 Consultations
0 Téléchargements
