Computing Chebyshev knot diagrams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
A Chebyshev curve $\cC(a,b,c,\phi)$ has a parametrization of the form $ x(t)=T_a(t)$; \ $y(t)=T_b(t)$; $z(t)= T_c(t + \phi)$, where $a,b,c$ are integers, $T_n(t)$ is the Chebyshev polynomial of degree $n$ and $\phi \in \RR$. When $\cC(a,b,c,\phi)$ is nonsingular, it defines a polynomial knot. We determine all possible knot diagrams when $\phi$ varies. Let $a,b,c$ be integers, $a$ is odd, $(a,b)=1$, we show that one can list all possible knots $\cC(a,b,c,\phi)$ in $\tcO(n^2)$ bit operations, with $n=abc$.
kprt_noels.pdf (417.45 Ko) Télécharger le fichier
hal-01232181 , version 1 (23-11-2015)
hal-01232181 , version 2 (12-05-2017)
P.-V Koseleff, D Pecker, Fabrice Rouillier, C Tran. Computing Chebyshev knot diagrams. 2015. ⟨hal-01232181v1⟩
307 Consultations
251 Téléchargements
