Motivating Use Cases for the Globalization of DSLs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
The development of complex software-intensive systems involves many stakeholders who contribute their expertise on specific aspects of the system under construction. Domain-specific languages (DSLs) are typically used by stakeholders to express their knowledge of the system using dedicated tools and abstractions. In this chapter, we explore different scenarios that lead to the globalization of DSLs through two motivating case studies – a command and control wind tunnel and a smart emergency response system – and outline the concrete engineering challenges they raise. Finally, we list some of the general research challenges related to the globalization of DSMLs and discuss some promising approaches for addressing them.
gemoc-dag144412.pdf (650.5 Ko) Télécharger le fichier
hal-01233660 , version 1 (25-11-2015)
Betty H.C. Cheng, Thomas Degueule, Colin Atkinson, Siobhan Clarke, Ulrich Frank, et al.. Motivating Use Cases for the Globalization of DSLs. Benoit Combemale; Betty H.C. Cheng; Robert B. France; Jean-Marc Jézéquel; Bernhard Rumpe. Globalizing Domain-Specific Languages, 9400, Springer International Publishing, pp.21-42, 2015, Lecture Notes in Computer Science, 978-3-319-26171-3. ⟨10.1007/978-3-319-26172-0_3⟩. ⟨hal-01233660⟩
201 Consultations
346 Téléchargements
