Projected event-capturing time-stepping schemes for nonsmooth mechanical systems with unilateral contact and Coulomb???s friction, Computer Methods in Applied Mechanics and Engineering, vol.256, pp.224-250, 2013. ,
DOI : 10.1016/j.cma.2012.12.012
Numerical Methods for Nonsmooth Dynamical Systems: Applications in Mechanics and Electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Convergence of the generalized-?? scheme for constrained mechanical systems, Multibody System Dynamics, vol.85, issue.10, pp.185-202, 2007. ,
DOI : 10.1007/s11044-007-9084-0
URL : https://hal.archives-ouvertes.fr/hal-01490825
Computer Methods for Ordinary Differential Equations and Differential?Algebraic Equations (SIAM, 1998. ,
A frictionless viscoelastodynamic contact problem with energy consistent properties: Numerical analysis and computational aspects, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8, 2009. ,
DOI : 10.1016/j.cma.2008.10.004
The dynamics of discrete mechanical systems with perfect unilateral constraints, Archives for Rational Mechanics and Analysis, pp.199-274, 2000. ,
Constrained integration of rigid body dynamics, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.3-5, pp.467-488, 2001. ,
DOI : 10.1016/S0045-7825(01)00283-3
Conservation properties of a time FE method?part III: Mechanical systems with holonomic constraints, International Journal for Numerical Methods in Engineering, vol.76, issue.10, pp.2271-2304, 2002. ,
DOI : 10.1002/nme.347
Nonsmooth Mechanics: Models, Dynamics and Control, Communications and Control Engineering, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01236953
Simultaneous enforcement of constraints at position and velocity levels in the nonsmooth generalized-<mml:math altimg="si17.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>??</mml:mi></mml:math> scheme, Computer Methods in Applied Mechanics and Engineering, vol.281, pp.131-161, 2014. ,
DOI : 10.1016/j.cma.2014.07.025
Time integration of the equations of motion in mechanism analysis, Computers & Structures, vol.33, issue.3, pp.801-820, 1989. ,
DOI : 10.1016/0045-7949(89)90255-1
Lagrange constraints for transient finite element surface contact, International Journal for Numerical Methods in Engineering, vol.1, issue.1, pp.103-108, 1992. ,
DOI : 10.1002/nme.1620320107
URL : https://hal.archives-ouvertes.fr/hal-01389918
Energy consistent algorithms for frictional contact problems, International Journal for Numerical Methods in Engineering, vol.5, issue.5, 1998. ,
DOI : 10.1002/(SICI)1097-0207(19980715)42:5<799::AID-NME385>3.0.CO;2-F
A Newmark-Type Integrator for Flexible Systems Considering Nonsmooth Unilateral Constraints, The Second Joint International Conference on Multibody System Dynamics -IMSD 2012, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00681252
scheme for flexible multibody systems with unilateral constraints, International Journal for Numerical Methods in Engineering, vol.23, issue.2, pp.487-511, 2013. ,
DOI : 10.1002/nme.4563
URL : https://hal.archives-ouvertes.fr/hal-00858066
A Time Integration Algorithm for Structural Dynamics With Improved Numerical Dissipation: The Generalized-?? Method, Journal of Applied Mechanics, vol.60, issue.2, pp.371-375, 1993. ,
DOI : 10.1115/1.2900803
33 years of numerical instability, Part I, BIT, vol.53, issue.1, pp.188-204, 1985. ,
DOI : 10.1007/BF01934997
Time-Integration Schemes for the Finite Element Dynamic Signorini Problem, SIAM Journal on Scientific Computing, vol.33, issue.1, pp.223-249, 2011. ,
DOI : 10.1137/100791440
URL : https://hal.archives-ouvertes.fr/hal-00440128
A sweeping process approach to inelastic contact problems with general inertia operators, European Journal of Mechanics - A/Solids, vol.26, issue.3, pp.474-490, 2007. ,
DOI : 10.1016/j.euromechsol.2006.07.002
A convergence result for a vibro-impact problem with a general inertia operator., Nonlinear Dyn, pp.361-384, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00867000
Non-Smooth Thermo-mechanics, 2002. ,
Automatic integration of Euler-Lagrange equations with constraints, Journal of Computational and Applied Mathematics, vol.12, issue.13, pp.77-90, 1985. ,
DOI : 10.1016/0377-0427(85)90008-1
Flexible Multibody Dynamics: A finite element Approach (J, 2001. ,
Time integration and discrete Hamiltonian systems, Journal of Nonlinear Science, vol.115, issue.5, pp.449-467, 1996. ,
DOI : 10.1007/BF02440162
Mechanical systems subject to holonomic constraints: Differential???algebraic formulations and conservative integration, Physica D: Nonlinear Phenomena, vol.132, issue.1-2, pp.165-174, 1999. ,
DOI : 10.1016/S0167-2789(99)00054-8
Exact energy and momentum conserving algorithms for general models in nonlinear elasticity, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.13-14, pp.1762-1783, 2000. ,
DOI : 10.1016/S0045-7825(00)00189-4
URL : https://hal.archives-ouvertes.fr/hal-01363585
Solving Ordinary Differential Equations II. Stiff and Differential-Algebraic Problems, 1996. ,
Energy-controlling time integration methods for nonlinear elastodynamics and low-velocity impact, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.37-40, pp.37-40, 2006. ,
DOI : 10.1016/j.cma.2005.11.005
URL : https://hal.archives-ouvertes.fr/hal-00111458
Improved numerical dissipation for time integration algorithms in structural dynamics, Earthquake Engineering & Structural Dynamics, vol.7, issue.3, pp.283-292, 1977. ,
DOI : 10.1002/eqe.4290050306
A note on the stability of Newmark's algorithm in nonlinear structural dynamics, International Journal for Numerical Methods in Engineering, vol.2, issue.2, pp.383-386, 1977. ,
DOI : 10.1002/nme.1620110212
The Finite Element Method, Linear Static and Dynamic Finite Element Analysis, 1987. ,
Extensions of the HHT?method to differentialalgebraic equations in mechanics, Electron. Trans. Numer. Anal, vol.26, pp.190-208, 2007. ,
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.235-257, 1999. ,
DOI : 10.1016/S0045-7825(98)00383-1
URL : https://hal.archives-ouvertes.fr/hal-01390459
Dynamics in the presence of unilateral contacts and dry friction: a numerical approach, in: Unilateral problems in structural analysis. II, CISM, vol.304, pp.151-196, 1987. ,
Finite element analysis of nonsmooth contact, Computer Methods in Applied Mechanics and Engineering, vol.180, issue.1-2, pp.1-26, 1999. ,
DOI : 10.1016/S0045-7825(99)00034-1
Probì emes de contact unilatéral avec forttement sec de Coilomb enélastostatiqueenélastostatique etélastodynamiqueetélastodynamique. ´ Etude mathématique et résolution numérique, Institut National des sciences appliquées de, 2005. ,
Presentation and comparison of selected algorithms for dynamic contact based on the Newmark scheme, Applied Numerical Mathematics, vol.62, issue.10, pp.1393-1410, 2012. ,
DOI : 10.1016/j.apnum.2012.06.014
Energy conservation in Newmark based time integration algorithms, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.44-47, pp.44-47, 2006. ,
DOI : 10.1016/j.cma.2005.12.001
Properties of time integration with first order filter damping, International Journal for Numerical Methods in Engineering, vol.6, issue.4, pp.547-566, 2005. ,
DOI : 10.1002/nme.1392
Computational Contact and Impact Mechanics ? Fundamentals of Modeling Interfacial Phenomena in Nonlinear Finite Element Analysis, 2003. ,
DESIGN OF ENERGY CONSERVING ALGORITHMS FOR FRICTIONLESS DYNAMIC CONTACT PROBLEMS, International Journal for Numerical Methods in Engineering, vol.37, issue.5, pp.863-886, 1997. ,
DOI : 10.1002/(SICI)1097-0207(19970315)40:5<863::AID-NME92>3.0.CO;2-V
URL : https://hal.archives-ouvertes.fr/hal-01435617
Improved implicit integrators for transient impact problems?geometric admissibility within the conserving framework, International Journal for Numerical Methods in Engineering, vol.32, issue.2, pp.245-274, 2002. ,
DOI : 10.1002/nme.264
Survey of the stability of linear finite difference equations, Communications on Pure and Applied Mathematics, vol.5, issue.2, pp.267-293, 1956. ,
DOI : 10.1002/cpa.3160090206
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
DOI : 10.1007/978-3-540-76975-0
Solving constrained mechanical systems by the family of Newmark and ??-methods, Zeitschrift für Angewandte Mathematik und Mechanik, pp.772-784, 2006. ,
DOI : 10.1002/zamm.200610285
Consistent Integrators for Non-Smooth Dynamical Systems, 2011. ,
Differential Inclusions in Nonsmooth Mechanical Problems. Shocks and Dry Friction, Progress in Nonlinear Differential Equations and their Applications, 1993. ,
Bounded variation in time, Topics in Nonsmooth Mechanics, pp.1-74, 1988. ,
URL : https://hal.archives-ouvertes.fr/hal-01363799
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications CISM, Courses and lectures (CISM 302, pp.1-82, 1988. ,
DOI : 10.1007/978-3-7091-2624-0_1
Numerical aspects of the sweeping process, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.329-349, 1999. ,
DOI : 10.1016/S0045-7825(98)00387-9
URL : https://hal.archives-ouvertes.fr/hal-01349847
A method of computation for structural dynamics, Journal of Engineering Mechanics, vol.85, issue.EM3, pp.67-94, 1959. ,
Multibody Dynamics with Unilateral Contacts, Non-linear Dynamics, 1996. ,
Difference Methods For Initial-Value Problems, Interscience tracts in pure and applied mathematics, 1967. ,
A class of nonlinear differential equations of second order in time, Nonlinear Analysis: Theory, Methods & Applications, vol.2, issue.3, pp.355-373, 1978. ,
DOI : 10.1016/0362-546X(78)90022-6
URL : https://hal.archives-ouvertes.fr/hal-01294058
Non-linear dynamics of three-dimensional rods: Exact energy and momentum conserving algorithms, International Journal for Numerical Methods in Engineering, vol.96, issue.9, pp.1431-1473, 1995. ,
DOI : 10.1002/nme.1620380903
The discrete energy-momentum method. Conserving algorithms for nonlinear elastodynamics, Zeitschrift für Angewandte Mathematik und Physik 43, pp.757-792, 1992. ,
DOI : 10.1007/BF00913408
Rigid-Body Dynamics with Friction and Impact, SIAM Review, vol.42, issue.1, pp.3-39, 2000. ,
DOI : 10.1137/S0036144599360110
An alpha modification of Newmark's method, International Journal for Numerical Methods in Engineering, vol.11, issue.10, pp.1562-1566, 1981. ,
DOI : 10.1002/nme.1620151011
Computational Contact Mechanics, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00466790
