AutoTuning and Adaptivity appRoach for Energy efficient eXascale HPC systems: the ANTAREX Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The main goal of the ANTAREX project is to express by a Domain Specific Language (DSL) the application self-adaptivity and to runtime manage and autotune applications for green and heterogeneous High Performance Computing (HPC) systems up to the Exascale level. Key innovations of the project include the introduction of a separation of concerns between self-adaptivity strategies and application functionalities. The DSL approach will allow the definition of energy-efficiency, performance, and adaptivity strategies as well as their enforcement at runtime through application autotuning and resource and power management.
Autre [cs.OH]
DATE-2016.pdf (191.36 Ko) Télécharger le fichier
hal-01235741 , version 1 (30-11-2015)
  • HAL Id : hal-01235741 , version 1
Cristina Silvano, Giovanni Agosta, Andrea Bartolini, Andrea R. Beccari, Luca Benini, et al.. AutoTuning and Adaptivity appRoach for Energy efficient eXascale HPC systems: the ANTAREX Approach. Design, Automation, and Test in Europe, Mar 2016, Dresden, Germany. ⟨hal-01235741⟩
912 Consultations
378 Téléchargements
