LIMITING MOTION FOR THE PARABOLIC GINZBURG-LANDAU EQUATION WITH INFINITE ENERGY DATA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Delphine Côte
  • Fonction : Auteur
  • PersonId : 773751
  • IdRef : 183957377
Raphaël Côte
  • Fonction : Auteur
  • PersonId : 181956
  • IdHAL : cote
  • IdRef : 119749351
We study a class of solutions to the parabolic Ginzburg-Landau equation in dimension 2 or higher, with ill-prepared infinite energy initial data. We show that, asymptotically, vorticity evolves according to motion by mean curvature in Brakke's weak formulation. Then, we prove that in the plane, point vortices do not move in the original time scale. These results extend the work of Bethuel, Orlandi and Smets [8, 9] for infinite energy data; they allow to consider the point vortices on a lattice (in dimension 2), or filament vortices of infinite length (in dimension 3).
GL_flow.pdf (520.19 Ko) Télécharger le fichier
hal-01235904 , version 1 (30-11-2015)
hal-01235904 , version 2 (25-02-2019)
Delphine Côte, Raphaël Côte. LIMITING MOTION FOR THE PARABOLIC GINZBURG-LANDAU EQUATION WITH INFINITE ENERGY DATA. 2015. ⟨hal-01235904v1⟩
367 Consultations
134 Téléchargements
