Parameter Setting for Multicore CMA-ES with Large Populations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of this paper is to investigate on the overall performance of CMA-ES, when dealing with a large number of cores — considering the direct mapping between cores and individuals — and to empirically find the best parameter strategies for a parallel machine. By considering the problem of parameter setting, we empirically determine a new strategy for CMA-ES, and we investigate whether Self-CMA-ES (a self-adaptive variant of CMA-ES) could be a viable alternative to CMA-ES when using parallel computers with a coarse-grained distribution of the fitness evaluations. According to a large population size, the resulting new strategy for Self-CMA-ES and CMA-ES, is experimentally validated on BBOB benchmark where it is shown to outperform a CMA-ES with default parameter strategy.
EA2015__20Empirical_Study_Self_CMAES.pdf (659.74 Ko) Télécharger le fichier
hal-01236025 , version 1 (01-12-2015)
  • HAL Id : hal-01236025 , version 1
Nacim Belkhir, Johann Dréo, Pierre Savéant, Marc Schoenauer. Parameter Setting for Multicore CMA-ES with Large Populations. Artificial Evolution (EA 2015), Oct 2015, Lyon, France. pp.109-122. ⟨hal-01236025⟩
320 Consultations
751 Téléchargements
