New interface
Journal articles
Lyapunov stability and performance analysis of the implicit discrete sliding mode control
Olivier Huber 1 Vincent Acary 1 Bernard Brogliato 1
1 BIPOP - Modelling, Simulation, Control and Optimization of Non-Smooth Dynamical Systems
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann
Abstract : Discrete-time sliding mode controllers with an implicit discretization of the signum function are considered.With a proper choice of the equivalent part of the control, the resulting controller is shown to be Lyapunov stable withfinite-time convergence of the sliding variable to $0$. The convergence of the control input, as the sampling period goes to $0$,to the continuous-time one is shown. The robustness with respect to matching perturbations is also investigated.The discretization performance in terms of the error order is studied for different discretizations of the equivalent part of the input.Numerical and experimental results illustrate and support the analysis.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01236159
Contributor : Bernard Brogliato Connect in order to contact the contributor
Submitted on : Monday, February 1, 2016 - 2:08:16 PM
Last modification on : Monday, July 25, 2022 - 3:44:21 AM
Long-term archiving on: : Friday, November 11, 2016 - 11:49:32 PM
File
TACON15-0916.pdf
Identifiers
Citation
Olivier Huber, Vincent Acary, Bernard Brogliato. Lyapunov stability and performance analysis of the implicit discrete sliding mode control. IEEE Transactions on Automatic Control, 2016, 61 (10), pp.3016-3030. ⟨10.1109/TAC.2015.2506991⟩. ⟨hal-01236159⟩
Share
Metrics
Record views
333
Files downloads
539
