Abstract : Estimating the worst-case execution time (WCET) of parallel applications running on many-core architectures is a significant challenge. Some approaches have been proposed, but they assume the mapping of parallel applications on cores already done. Unfortunately, on architectures with caches, task mapping requires a priori known WCETs for tasks, which in turn requires knowing task mapping (i.e., co-located tasks, co-running tasks) to have tight WCET bounds. Therefore, scheduling parallel applications and estimating their WCET introduce a chicken and egg situation. In this paper, we address this issue by developing an optimal integer linear programming formulation for solving the scheduling problem, whose objective is to minimize the WCET of a parallel application. Our proposed static partitioned non-preemptive mapping strategy addresses the effect of local caches to tighten the estimated WCET of the parallel application. We report preliminary results obtained on synthetic parallel applications.
