A formulation of the linear discrete Coulomb friction problem via convex optimization, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.5, issue.4, pp.91155-175, 2011. ,
DOI : 10.1002/zamm.201000073
URL : https://hal.archives-ouvertes.fr/inria-00495734
A mixed formulation for frictional contact problems prone to Newton like solution methods, Computer Methods in Applied Mechanics and Engineering, vol.92, issue.3, pp.353-375, 1991. ,
DOI : 10.1016/0045-7825(91)90022-X
A nonlinear domain decomposition formulation with application to granular dynamics, Computer Methods in Applied Mechanics and Engineering, vol.205, issue.208, pp.205-20859, 2012. ,
DOI : 10.1016/j.cma.2011.04.024
URL : https://hal.archives-ouvertes.fr/hal-00597519
On implementing a primal-dual interior-point method for conic quadratic optimization, Mathematical Programming, pp.95249-277, 2003. ,
DOI : 10.1007/s10107-002-0349-3
The material-point method for granular materials, Computer Methods in Applied Mechanics and Engineering, vol.187, issue.3-4, pp.3-4529, 2000. ,
DOI : 10.1016/S0045-7825(99)00338-2
Well-posed and ill-posed behaviour of the -rheology for granular flow, Journal of Fluid Mechanics, vol.91, pp.794-818, 2015. ,
DOI : 10.1146/annurev-fluid-122109-160705
Two-Point Step Size Gradient Methods, IMA Journal of Numerical Analysis, vol.8, issue.1, pp.141-148, 1988. ,
DOI : 10.1093/imanum/8.1.141
The flow of granular solids through orifices, Chemical Engineering Science, vol.15, issue.3-4, pp.3-4260, 1961. ,
DOI : 10.1016/0009-2509(61)85030-6
Efficient numerical computations of yield stress fluid flows using second-order cone programming, Computer Methods in Applied Mechanics and Engineering, vol.283, pp.599-614, 2015. ,
DOI : 10.1016/j.cma.2014.10.008
URL : https://hal.archives-ouvertes.fr/hal-01081508
Optimization and convex analysis for nonsmooth dynamics. Theses, 2009. ,
URL : https://hal.archives-ouvertes.fr/tel-00440798
Numerical simulations of granular free-surface flows using smoothed particle hydrodynamics, Journal of Non-Newtonian Fluid Mechanics, vol.166, issue.12-13, pp.12-13698, 2011. ,
DOI : 10.1016/j.jnnfm.2011.03.007
A three-dimensional numerical model for dense granular flows based on the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>??</mml:mi><mml:mo stretchy="false">(</mml:mo><mml:mi>I</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math> rheology, Journal of Computational Physics, vol.256, pp.696-712, 2014. ,
DOI : 10.1016/j.jcp.2013.09.004
Dense granular flow around an immersed cylinder, Physics of Fluids, vol.15, issue.6, p.1622, 2003. ,
DOI : 10.1063/1.1571826
A hybrid iterative solver for robustly capturing coulomb friction in hair dynamics, ACM Transactions on Graphics, vol.30, issue.6, p.1, 2011. ,
DOI : 10.1145/2070781.2024173
URL : https://hal.archives-ouvertes.fr/hal-00647497
The bipotential method: A constructive approach to design the complete contact law with friction and improved numerical algorithms, Mathematical and Computer Modelling, vol.28, pp.4-8225, 1998. ,
Full two-dimensional rapid chute flows of simple viscoplastic granular materials with a pressure-dependent dynamic slip-velocity and their numerical simulations, Journal of Non-Newtonian Fluid Mechanics, vol.173, issue.174, pp.173-17472, 2012. ,
DOI : 10.1016/j.jnnfm.2012.03.001
Continuum modelling and simulation of granular flows through their many phases, Journal of Fluid Mechanics, vol.4, pp.483-513, 2015. ,
DOI : 10.1103/PhysRevLett.113.178001
Méthodes de lagrangien augmenté. application à la résolution numérique de problèmes aux limites, 1982. ,
On the usage of viscosity regularisation methods for visco-plastic fluid flow computation, Journal of Non-Newtonian Fluid Mechanics, vol.127, issue.1, pp.1-26, 2005. ,
DOI : 10.1016/j.jnnfm.2005.01.003
On dense granular flows, The European Physical Journal E, vol.4, issue.4, pp.341-365, 2004. ,
DOI : 10.1140/epje/i2003-10153-0
URL : https://hal.archives-ouvertes.fr/hal-00000959
Approximation and numerical solution of contact problems with friction, Aplikace matematiky, vol.28, issue.1, pp.55-71, 1983. ,
On the modeling, simulation , and visualization of many-body dynamics problems with friction and contact, 2013. ,
Fundamentals of convex analysis. Grundlehren text editions, 2001. ,
Viscoplastic modeling of granular column collapse with pressuredependent rheology, Journal of Non-Newtonian Fluid Mechanics, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01080456
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.3-4235, 1999. ,
DOI : 10.1016/S0045-7825(98)00383-1
URL : https://hal.archives-ouvertes.fr/hal-01390459
A constitutive law for dense granular flows, Nature, vol.94, issue.7094, pp.441727-730, 2006. ,
DOI : 10.1038/nature04801
URL : https://hal.archives-ouvertes.fr/hal-01432178
Nonlinear elasto-plastic model for dense granular flow, International Journal of Plasticity, vol.26, issue.2, pp.167-188, 2010. ,
DOI : 10.1016/j.ijplas.2009.06.007
An inexact interior point method for the large-scale simulation of granular material, Computer Methods in Applied Mechanics and Engineering, vol.278, pp.567-598, 2014. ,
DOI : 10.1016/j.cma.2014.06.009
The granular column collapse as a continuum: validity of a two-dimensional Navier???Stokes model with a ??(I)-rheology, Journal of Fluid Mechanics, vol.4, pp.378-408, 2011. ,
DOI : 10.1088/0169-5983/41/6/065001
A contact dynamics approach to the Granular Element Method, Computer Methods in Applied Mechanics and Engineering, vol.268, pp.557-573, 2014. ,
DOI : 10.1016/j.cma.2013.10.004
The flow rate of granular materials through an orifice, Granular Matter, vol.38, issue.6, pp.407-414, 2007. ,
DOI : 10.1007/s10035-007-0062-2
Numerical aspects of the sweeping process, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.3-4329, 1999. ,
DOI : 10.1016/S0045-7825(98)00387-9
URL : https://hal.archives-ouvertes.fr/hal-01349847
A method of solving a convex programming problem with convergence rate o (1/k2), Soviet Mathematics Doklady, vol.27, issue.2, pp.372-376, 1983. ,
Conjugate gradient type algorithms for frictional multi-contact problems: applications to granular materials, Computer Methods in Applied Mechanics and Engineering, vol.194, pp.18-202019, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01393138
Efficient C++ finite element computing with Rheolef, Lecture, 2015. ,
URL : https://hal.archives-ouvertes.fr/cel-00573970
An adaptive finite element method for viscoplastic fluid flows in pipes, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.40-41, pp.40-415391, 2001. ,
DOI : 10.1016/S0045-7825(01)00175-X
The granular silo as a continuum plastic flow: The hour-glass vs the clepsydra, Physics of Fluids, vol.24, issue.10, p.24103301, 2012. ,
DOI : 10.1063/1.4757390
URL : https://hal.archives-ouvertes.fr/hal-01444556
Continuum simulation of the discharge of the granular silo, The European Physical Journal E, vol.110, issue.1, 2014. ,
DOI : 10.1140/epje/i2014-14005-6
URL : https://hal.archives-ouvertes.fr/hal-01444558
Efficient simulation of contacts, friction and constraints using a modified spectral projected gradient method, Poster Proceedings of WSCG 2013, pp.69-72, 2013. ,
A two-scale model of granular materials, Computer Methods in Applied Mechanics and Engineering, vol.205, issue.208, pp.205-20846, 2012. ,
DOI : 10.1016/j.cma.2010.12.023
