Cryptanalysis of Full Sprout
A new method for reducing the internal state size of stream
cipher registers has been proposed in FSE 2015, allowing to reduce the
area in hardware implementations. Along with it, an instantiated proposal
of a cipher was also proposed: Sprout. In this paper, we analyze
the security of Sprout, and we propose an attack that recovers the whole
key more than 210 times faster than exhaustive search and has very low
data complexity. The attack can be seen as a divide-and-conquer evolved
technique, that exploits the non-linear in
uence of the key bits on the
update function. We have implemented the attack on a toy version of
Sprout, that conserves the main properties exploited in the attack. The
attack completely matches the expected complexities predicted by our
theoretical cryptanalysis, which proves its validity. We believe that our
attack shows that a more careful analysis should be done in order to
instantiate the proposed design method.
