Abstract : Prior to 1900, almost every mechanical calculating
machine was aimed at facilitating a standard arithmetic
operation, and it tried to do so in a general way. For
instance, the first machines were adding machines, and
they could add any two numbers, depending on the
size of the machine. In some cases, the machines were
tailored for specific needs, such as adding nondecimal
monetary units. Most of the early multiplying
machines were in fact adding machines, but the multi-
plicand could be stored, shifted, and reused in a new
addition, although usually not automatically. Some
machines were equipped with automatic shifts, and
toward the end of the 19th century, some multiplica-
tion machines were based on stored tables, allowing for
shortcuts. All these machines were aimed at general
multiplication.
