Individual-Based Mitral Valve Finite-Element Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mitral valve surgical repair is a complex procedure where the outcome largely depends on the surgeons’ experience. Predicting a good coaptation of the two leaflets post-operatively is one of the most difficult sub-tasks in the procedure. We propose a biomechanical simulation framework that computes the leaflet deformation and coaptation based on micro CT data as an initial step toward patient-based mitral valve surgical repair assistance though simulation.
Format : Figure, Image
hal-01237756 , version 1 (03-12-2015)
  • HAL Id : hal-01237756 , version 1
Pierre-Frédéric Villard, Peter E. Hammer, Douglas P. Perrin, Pedro J. del Nido, Robert Howe. Individual-Based Mitral Valve Finite-Element Model. Innovation, Design, and Emerging Alliances in Surgery, Mar 2015, Boston, United States. ⟨hal-01237756⟩
143 Consultations
17 Téléchargements
