Experimental results on implicit and explicit time-discretization of equivalent-control-based sliding-mode control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
This chapter presents a set of experimental results concerning the sliding mode control of an electro-pneumatic system. The controller is implemented {\em via} a micro-processor as a discrete-time input. Three discrete-time control strategies are considered for the implementation of the discontinuous part of the sliding mode controller: explicit discretizations with and without saturation, and an implicit discretization (that is very easy to implement as a projection on the interval [-1,1]). While the explicit implementation is known to generate numerical chattering, the implicit one is expected to significantly reduce chattering while keeping the accuracy. The experimental results reported in this work remarkably confirm that the implicit discrete-time sliding mode supersedes the explicit ones, with several important features: chattering in the control input is almost eliminated (while the explicit and saturated controllers behave like high-frequency bang-bang inputs), the input magnitude depends only on the perturbation size and is ``independent'' of the controller gain and sampling time. On the contrary the explicit controller shows obvious chattering for all sampling times, its magnitude increases as the controller gain increases, and it does not reduce when the sampling period augments. The tracking errors are comparable for both methods, though the implicit method keeps the precision when the control gain increases, which is not the case for the explicit one. Introducing a saturation in the explicit controller does not allow to significantly improve the explicit controller behaviour if one does not take care of the saturation width.
OHBBVATT.pdf (1.7 Mo) Télécharger le fichier
hal-01238120 , version 1 (03-11-2017)
Olivier Huber, Bernard Brogliato, Vincent Acary, Ahcene Boubakir, Franck Plestan, et al.. Experimental results on implicit and explicit time-discretization of equivalent-control-based sliding-mode control. L. Fridman; J.P. Barbot; F. Plestan. Recent Trends in Sliding Mode Control, 102, IET, pp.207-235, 2016, IET Control, Robotics and Sensors Series, 978-1-78561-076-9. ⟨10.1049/PBCE102E_ch3.2⟩. ⟨hal-01238120⟩
553 Consultations
335 Téléchargements
