New interface
Journal articles
Spectral recycling strategies for the solution of nonlinear eigenproblems in thermoacoustics
Abstract : In this work we consider the numerical solution of large nonlinear eigenvalue problems that arise in thermoacoustic simulations involved in the stability analysis of large combustion devices. We briefly introduce the physical modeling that leads to a non-linear eigenvalue problem that is solved using a nonlinear fixed point iteration scheme. Each step of this nonlinear method requires the solution of a complex non-Hermitian linear eigenvalue problem. We review a set of state of the art eigensolvers and discuss strategies to recycle spectral informations from one nonlinear step to the next. More precisely, we consider the Implicitly Restarted Arnoldi method, the Krylov-Schur solver and its block-variant as well as the subspace iteration method with Chebyshev acceleration. On a small test example we study the relevance of the different approaches and illustrate on a large industrial test case the performance of the parallel solvers best suited to recycle spectral information.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-01238263
Contributor : Luc Giraud Connect in order to contact the contributor
Submitted on : Friday, December 4, 2015 - 3:40:21 PM
Last modification on : Friday, December 9, 2022 - 12:19:25 PM
Long-term archiving on: : Saturday, April 29, 2017 - 4:25:32 AM
File
paper.pdf
Identifiers
Collections
Citation
Pablo Salas, Luc Giraud, Yousef Saad, Stéphane Moreau. Spectral recycling strategies for the solution of nonlinear eigenproblems in thermoacoustics. Numerical Linear Algebra with Applications, 2015, 22 (6), pp.1039-1058. ⟨10.1002/nla.1995⟩. ⟨hal-01238263⟩
Share
Metrics
Record views
214
Files downloads
138
