High-Level Functional Properties of Bit-Level Programs: Formal Specifications and Automated Proofs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Propriétés fonctionnelles de haut-niveau pour des programmes opérant au niveau des bits: spécifications formelles et preuves automatiques
In a computer program, basic functionalities may be implemented using bit-wise operations. This can be motivated by the need to be close to the underlying architecture, or the need of efficiency, both in term of time and memory space. If one wants to formally specify the expected behavior of such a low-level program, it is desirable that the specification should be at a more abstract level. Formally proving that a low-level code conforms to a higher-level specification is challenging, because of the gap between the different levels of abstraction. Our approach to address this challenge is to design a rich formal theory of fixed-sized bit-vectors, which on the one hand allows a user to write abstract specifications close to the human---or mathematical---level of thinking, while on the other hand permits a close connection to decision procedures and tools for bit-vectors, as they exist in the context of the Satisfiability Modulo Theory framework. This approach is implemented in the Why3 environment for deductive program verification, and also in its front-end environment SPARK for the development of safety-critical Ada programs. We report on several case studies used to validate our approach experimentally.
Dans un programme informatique, des fonctionalités de base sont parfois implémentées par des opérations bit-à-bit, par exemple à cause d'un besoin d'être proche de l'architecture matérielle sous-jacente, ou bien pour des questions d'efficacité, aussi bien en temps de calcul qu'en place mémoire. Si l'on cherche à spécifier formellement le comportement attendu d'un tel programme, il est souhaitable que la spécification se place à un niveau plus abstrait que celui des bits. Prouver formellement qu'un programme bas niveau est conforme à une spécification de plus haut niveau est un défi, à cause de l'écart important entre les niveaux d'abstraction en jeu. Notre approche pour résoudre ce défi consiste à concevoir une théorie formelle des vecteurs de bits, qui d'une part permet à un utilisateur d'écrire des spécifications proches d'un niveau de conception humain (ou bien disons, mathématique), et d'autre part peut se connecter aux procédures de décision et aux outils sachant traiter les vecteurs de bits, comme ceux qui sont développés dans le cadre SMT (Satisfia-bility Modulo Theory). Cette approche est implémentée dans le cadre de l’environnement généraliste Why3 pour la preuve déprogramme, ainsi que dans l’environnement SPARK pour le développement de codes critiques en Ada, qui utilise Why3 en interne. Nous présentons plusieurs études de cas afin de valider notre approche.
RR-8821.pdf (778.29 Ko) Télécharger le fichier
hal-01238376 , version 1 (04-12-2015)
  • HAL Id : hal-01238376 , version 1
Claire Dross, Clément Fumex, Jens Gerlach, Claude Marché. High-Level Functional Properties of Bit-Level Programs: Formal Specifications and Automated Proofs. [Research Report] RR-8821, Inria Saclay. 2015, pp.52. ⟨hal-01238376⟩
304 Consultations
578 Téléchargements
