A Teaching System To Learn Programming: the Programmer's Learning Machine
The Programmer's Learning Machine (PLM) is an interactive exerciser for learning programming and algorithms. Using an integrated and graphical environment that provides a short feedback loop, it allows students to learn in a (semi)-autonomous way. This generic platform also enables teachers to create specific programming microworlds that match their teaching goals. This paper discusses our design goals and motivations, introduces the existing material and the proposed microworlds, and details the typical use cases from the student and teacher point of views.
plm-iticse-HAL.pdf (647.16 Ko)
Télécharger le fichier
2015-itiCSE-plm-slides.pdf (799.43 Ko)
