A New Methodology for Tolerance Synthesis of Parallel Manipulators
Abstract : Computing the maximal pose error given an upper bound on perturbations is challenging for parallel robots, mainly because the direct kinematic problem has several solutions, which become unstable near or at parallel singularities. In this paper, we propose a local uniqueness hypothesis that will allow safely computing pose error upper bounds using nonlinear optimization. This hypothesis , together with a corresponding maximal allowed perturbation domain and a certified pose error upper bound valid over the complete workspace, will be proved numerically using a parametric version of Kantorovich theorem and certified nonlinear global optimization. We will then show how to synthesize tolerances reaching a prescribed maximal pose error over a workspace using approximate linearizations. This approximate tolerance synthesis will finally be checked using the certified pose error upper bound we propose. Preliminary experiments on a RPRPR and a 3RPR with fixed orientation parallel manipulators are presented .
Liste complète des métadonnées
Littérature citée [19 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-01238717
Contributeur : Gilles Chabert <>
Soumis le : lundi 7 décembre 2015 - 08:06:14
Dernière modification le : lundi 16 juillet 2018 - 10:09:48
Document(s) archivé(s) le : samedi 29 avril 2017 - 05:24:04
Fichier
goldsztejn_et_al_iftomm15.pdf
Fichiers produits par l'(les) auteur(s)
Citation
A Goldsztejn, S Caro, Gilles Chabert. A New Methodology for Tolerance Synthesis of Parallel Manipulators. IFToMM 2015, 2015, Taipei, Taiwan. 〈http://www.iftomm2015.tw/〉. 〈10.6567/IFToMM.14TH.WC.OS12.017〉. 〈hal-01238717〉
Métriques
Consultations de la notice
600
Téléchargements de fichiers
113
