Preprints, Working Papers, ...
Atomic Read/Write Memory in Signature-free Byzantine Asynchronous Message-passing Systems
Abstract : This article presents a signature-free distributed algorithm which builds an atomic read/write shared memory on top of an n-process asynchronous message-passing system in which up to t < n/3 processes may commit Byzantine failures. From a conceptual point of view, this algorithm is designed to be as close as possible to the algorithm proposed by Attiya, Bar-Noy and Dolev (JACM 1995), which builds an atomic register in an n-process asynchronous message-passing system where up to t < n/2 processes may crash. The proposed algorithm is particularly simple. It does not use cryptography to cope with Byzantine processes, and is optimal from a t-resilience point of view (t < n/3). A read operation requires O(n) messages, and a write operation requires O(n 2) messages. Mémoire partagée fiable dans les systèmes asynchones avec processus Byzantins Résumé : Cet article présente une construction de mémoire partagée au dessus d'un système asynchone à passage de messages dans lequel jusqu'à t < n/3 processus peuvent avoir des comportements arbitraires (fautes Byzantines), n étant le nombre total de processsus.
Document type :
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01238765
Contributor : Michel Raynal Connect in order to contact the contributor
Submitted on : Tuesday, December 8, 2015 - 3:41:43 PM
Last modification on : Monday, June 27, 2022 - 3:02:01 AM
Long-term archiving on: : Wednesday, March 9, 2016 - 11:43:24 AM
File
RR-2028-SeqNb-Byz-memmory.pdf
Identifiers
  • HAL Id : hal-01238765, version 1
Citation
Achour Mostefaoui, Matoula Petrolia, Michel Raynal, Claude Jard. Atomic Read/Write Memory in Signature-free Byzantine Asynchronous Message-passing Systems. 2015. ⟨hal-01238765⟩
Share
Metrics
Record views
219
Files downloads
208
