Efficient customisable dynamic motion planning for assistive robots in complex human environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue JAISE - Journal of Ambient Intelligence and Smart Environments Année : 2015
People with impaired physical and mental ability often find it challenging to negotiate crowded or unfamiliar environments, leading to a vicious cycle of deteriorating mobility and sociability. To address this issue we present a novel motion planning algorithm that is able to intelligently deal with crowded areas, permanent or temporary anomalies in the environment (e.g., road blocks, wet floors) as well as hard and soft constraints (e.g., " keep a toilet within reach of 10 meters during the journey ", " always avoid stairs "). Constraints can be assigned a priority tailored to the user's needs. The planner has been validated by means of simulations and experiments with elderly people within the context of the DALi European project.
JAISE15_dali.pdf (3.6 Mo) Télécharger le fichier
hal-01239099 , version 1 (07-12-2015)
Alessio Colombo, Daniele Fontanelli, Axel Legay, Luigi Palopoli, Sean Sedwards. Efficient customisable dynamic motion planning for assistive robots in complex human environments. JAISE - Journal of Ambient Intelligence and Smart Environments, 2015, ⟨10.3233/AIS-150338⟩. ⟨hal-01239099⟩
335 Consultations
244 Téléchargements
