Numeric and Certified Isolation of the Singularities of the Projection of a Smooth Space Curve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Let CP ∩Q be a smooth real analytic curve embedded in R 3 , defined as the solutions of real analytic equations of the form P (x, y, z) = Q(x, y, z) = 0 or P (x, y, z) = ∂P ∂z = 0. Our main objective is to describe its projection C onto the (x, y)-plane. In general, the curve C is not a regular submanifold of R 2 and describing it requires to isolate the points of its singularity locus Σ. After describing the types of singularities that can arise under some assumptions on P and Q, we present a new method to isolate the points of Σ. We experimented our method on pairs of independent random polynomials (P, Q) and on pairs of random polynomials of the form (P, ∂P ∂z) and got promising results.
macis_paper_19.pdf (454.17 Ko) Télécharger le fichier
hal-01239447 , version 1 (07-12-2015)
  • HAL Id : hal-01239447 , version 1
Rémi Imbach, Guillaume Moroz, Marc Pouget. Numeric and Certified Isolation of the Singularities of the Projection of a Smooth Space Curve. Proceedings of the 6th International Conferences on Mathematical Aspects of Computer and Information Sciences, Oct 2015, Berlin, Germany. ⟨hal-01239447⟩
302 Consultations
254 Téléchargements
