Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.301, pp.300-335, 2016. ,
DOI : 10.1016/j.cma.2015.12.015
URL : https://hal.archives-ouvertes.fr/hal-01149225
Robin based semi-implicit coupling in fluidstructure interaction: Stability analysis and numerics, SIAM J. Sci. Comput, issue.6, pp.314041-4065, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00361284
Fluid???structure interaction and multi-body contact: Application to aortic valves, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.45-46, pp.45-463603, 2009. ,
DOI : 10.1016/j.cma.2008.09.012
URL : https://hal.archives-ouvertes.fr/inria-00542238
Convergence analysis of a projection semi-implicit coupling scheme for fluid???structure interaction problems, Numerische Mathematik, vol.96, issue.1, pp.721-767, 2010. ,
DOI : 10.1007/s00211-010-0311-x
URL : https://hal.archives-ouvertes.fr/hal-00860416
Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, pp.7027-7051, 2008. ,
DOI : 10.1016/j.jcp.2008.04.006
Robin-Robin preconditioned Krylov methods for fluidstructure interaction problems, Comput. Methods Appl. Mech. Engrg, vol.198, pp.33-362768, 2009. ,
Modular vs. non-modular preconditioners for fluid???structure systems with large added-mass effect, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.49-50, pp.49-504216, 2008. ,
DOI : 10.1016/j.cma.2008.04.018
Splitting Methods Based on Algebraic Factorization for Fluid-Structure Interaction, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1778-1805, 2008. ,
DOI : 10.1137/070680497
A convergence study of a new partitioned fluid???structure interaction algorithm based on fictitious mass and damping, Journal of Computational Physics, vol.231, issue.2, pp.629-652, 2012. ,
DOI : 10.1016/j.jcp.2011.09.025
PETSc users manual, 2014. ,
Efficient management of parallelism in object oriented numerical software libraries An analysis of a new stable partitioned algorithm for FSI problems. Part II: Incompressible flow and structural shells, Modern Software Tools in Scientific Computing, pp.163-202399, 1997. ,
Patient-specific isogeometric fluid???structure interaction analysis of thoracic aortic blood flow due to implantation of the Jarvik 2000 left ventricular assist device, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.45-46, pp.1983534-3550, 2009. ,
DOI : 10.1016/j.cma.2009.04.015
Identification of artery wall stiffness: In vitro validation and in vivo results of a data assimilation procedure applied to a 3D fluid???structure interaction model, Journal of Biomechanics, vol.47, issue.5, pp.471027-1034, 2014. ,
DOI : 10.1016/j.jbiomech.2013.12.029
URL : https://hal.archives-ouvertes.fr/hal-00925902
Fluid???structure interaction in blood flow capturing non-zero longitudinal structure displacement, Journal of Computational Physics, vol.235, issue.0, pp.515-541, 2013. ,
DOI : 10.1016/j.jcp.2012.08.033
A modular, operator-splitting scheme for fluid-structure interaction problems with thick structures, Int. J. Numer. Meth. Fluids, issue.8, pp.74577-604, 2014. ,
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8766, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
Explicit strategies for incompressible fluid-structure interaction problems: Nitsche type mortaring versus Robin-Robin coupling, International Journal for Numerical Methods in Engineering, vol.13, issue.1, 2013. ,
DOI : 10.1002/nme.4607
URL : https://hal.archives-ouvertes.fr/hal-00819948
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/hal-00695954
The Finite Element Analysis of Shells -Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
MODELING OF THE INCLUSION OF A REINFORCING SHEET WITHIN A 3D MEDIUM, Mathematical Models and Methods in Applied Sciences, vol.13, issue.04, pp.573-595, 2003. ,
DOI : 10.1142/S0218202503002635
URL : https://hal.archives-ouvertes.fr/hal-00839241
Parallel Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, SIAM Journal on Scientific Computing, vol.33, issue.4, pp.1598-1622, 2011. ,
DOI : 10.1137/090772836
Partitioned Simulation of Fluid-Structure Interaction, Archives of Computational Methods in Engineering, vol.196, issue.8, pp.185-238, 2013. ,
DOI : 10.1007/s11831-013-9085-5
Stability of a coupling technique for partitioned solvers in FSI applications, Computers & Structures, vol.86, issue.23-24, pp.23-242224, 2008. ,
DOI : 10.1016/j.compstruc.2008.05.005
A continuum mechanics based four???node shell element for general non???linear analysis, Engineering Computations, vol.1, issue.1, pp.77-88, 1984. ,
DOI : 10.1108/eb023562
Effect of baffles on a partially filled cubic tank: Numerical simulation and experimental validation, Computers & Structures, vol.87, issue.3-4, pp.3-4198, 2009. ,
DOI : 10.1016/j.compstruc.2008.10.008
Coupling schemes for incompressible fluid-structure interaction: implicit, semi-implicit and explicit, SeMA Journal, vol.40, issue.12, pp.59-108, 2011. ,
DOI : 10.1007/BF03322593
Incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible fluid, Comptes Rendus Mathematique, vol.349, issue.7-8, pp.473-477, 2011. ,
DOI : 10.1016/j.crma.2011.03.001
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1007/s00211-012-0481-9
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.021
Convergence and error analysis for a class of splitting schemes in incompressible fluid???structure interaction, IMA Journal of Numerical Analysis, vol.36, issue.4, 2015. ,
DOI : 10.1093/imanum/drv055
Explicit Robin???Neumann schemes for the coupling of incompressible fluids with thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.566-593, 2013. ,
DOI : 10.1016/j.cma.2013.09.020
Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction: Stability analysis and numerics, International Journal for Numerical Methods in Engineering, vol.38, issue.6-7, pp.199-229, 2015. ,
DOI : 10.1002/nme.4785
Fully decoupled time-marching schemes for incompressible fluid/thin-walled structure interaction, Journal of Computational Physics, vol.297, issue.0, pp.156-181, 2015. ,
DOI : 10.1016/j.jcp.2015.05.009
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7, pp.1278-1293, 2007. ,
DOI : 10.1016/j.cma.2006.09.002
Benchmark experiment for validation of fluid-structure interaction algorithms, 4th International Conference on Computational & Mathematical Biomedical Engineering (CMBE15), 2015. ,
Truly monolithic algebraic multigrid for fluid-structure interaction, International Journal for Numerical Methods in Engineering, vol.33, issue.2, pp.987-1016, 2011. ,
DOI : 10.1002/nme.3001
PVM?parallel virtual machine: a users' guide and tutorial for networked parallel computing Gerbeau and M. Vidrascu. A quasi-Newton algorithm based on a reduced model for fluid-structure interactions problems in blood flows, Math. Model. Num. Anal, vol.37, issue.4, pp.631-648, 1994. ,
Fluid???structure interaction in blood flows on geometries based on medical imaging, Computers & Structures, vol.83, issue.2-3, pp.155-165, 2005. ,
DOI : 10.1016/j.compstruc.2004.03.083
Stable loosely-coupled-type algorithm for fluid???structure interaction in blood flow, Journal of Computational Physics, vol.228, issue.18, pp.6916-6937, 2009. ,
DOI : 10.1016/j.jcp.2009.06.007
Fluid-Structure Interaction in Internal Physiological Flows, Annual Review of Fluid Mechanics, vol.43, issue.1, pp.141-162, 2011. ,
DOI : 10.1146/annurev-fluid-122109-160703
Abstract, Communications in Computational Physics, vol.19, issue.02, pp.337-377, 2012. ,
DOI : 10.1006/jcph.1999.6356
An immersogeometric variational framework for fluid???structure interaction: Application to bioprosthetic heart valves, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.1005-1053, 2015. ,
DOI : 10.1016/j.cma.2014.10.040
Coupling strategies for biomedical fluid-structure interaction problems, International Journal for Numerical Methods in Biomedical Engineering, vol.10, issue.4, pp.3-4305, 2009. ,
DOI : 10.1002/cnm.1281
Domain decomposition methods in computational mechanics, Computational Mechanics Advances, pp.121-220, 1994. ,
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
Solving large scale structural problems on parallel computers using domain decomposition techniques, Parallel Solution Methods in Computational Mechanics, pp.49-82, 1997. ,
A stable second-order scheme for fluid???structure interaction with strong added-mass effects, Journal of Computational Physics, vol.270, pp.687-710, 2014. ,
DOI : 10.1016/j.jcp.2014.04.020
Extending the Range and Applicability of the Loose Coupling Approach for FSI Simulations, Fluid-Structure Interaction, pp.82-100, 2006. ,
DOI : 10.1007/3-540-34596-5_4
Numerical Simulation of Sailing Boats: Dynamics, FSI, and Shape Optimization, Variational Analysis and Aerospace Engineering: Mathematical Challenges for Aerospace Design, pp.339-377, 2012. ,
DOI : 10.1007/978-1-4614-2435-2_15
Kinematic splitting algorithm for fluid???structure interaction in hemodynamics, Computer Methods in Applied Mechanics and Engineering, vol.265, issue.1, pp.83-106, 2013. ,
DOI : 10.1016/j.cma.2013.05.025
Balancing domain decomposition, Communications in Numerical Methods in Engineering, vol.13, issue.3, pp.233-241, 1993. ,
DOI : 10.1002/cnm.1640090307
Goal oriented error estimators for Stokes equations based on variationally consistent postprocessing, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.5-6, pp.5-6613, 2003. ,
DOI : 10.1016/S0045-7825(02)00575-3
A comparison of outlet boundary treatments for prevention of backflow divergence with relevance to blood flow simulations, Computational Mechanics, vol.65, issue.41???43, pp.277-291, 2011. ,
DOI : 10.1007/s00466-011-0599-0
Sequential identification of boundary support parameters in a fluid-structure vascular model using patient image data, Biomech. Model. Mechanobiol, vol.12, issue.3, pp.475-496, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00760703
External tissue support and fluid-structure simulation in blood flows, Biomech. Model. Mechanobiol, vol.11, pp.1-18, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00701801
An efficient preconditioner for monolithically-coupled large-displacement fluid???structure interaction problems with pseudo-solid mesh updates, Journal of Computational Physics, vol.231, issue.21, pp.7315-7334, 2012. ,
DOI : 10.1016/j.jcp.2012.07.001
Time accurate partitioned algorithms for the solution of fluid???structure interaction problems in haemodynamics, Computers & Fluids, vol.86, pp.470-482, 2013. ,
DOI : 10.1016/j.compfluid.2013.07.031
Inexact accurate partitioned algorithms for fluid???structure interaction problems with finite elasticity in haemodynamics, Journal of Computational Physics, vol.273, pp.598-617, 2014. ,
DOI : 10.1016/j.jcp.2014.05.020
Fluid-structure interactions: cross-flowinduced instabilities, 2011. ,
Experimental and numerical study on a laminar fluid???structure interaction reference test case, Journal of Fluids and Structures, vol.27, issue.1, pp.43-61, 2011. ,
DOI : 10.1016/j.jfluidstructs.2010.09.004
Computational hydrodynamics of capsules and biological cells, CRC Mathematical and Computational Biology, vol.20103131, 2010. ,
DOI : 10.1201/EBK1439820056
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.06, pp.957-983, 2007. ,
DOI : 10.1142/S0218202507002170
A monolithic geometric multigrid solver for fluid-structure interactions in ALE formulation, International Journal for Numerical Methods in Engineering, vol.76, issue.2 and 3, pp.372-390, 2015. ,
DOI : 10.1002/nme.4943
Finite elements for fluid?structure interaction in ALE and fully eulerian coordinates, Comput. Methods Appl. Mech. Engrg, vol.199, pp.41-442633, 2010. ,
Domain Decomposition, 1996. ,
DOI : 10.1007/978-3-540-70529-1_411
Mesh Moving Techniques for Fluid-Structure Interactions With Large Displacements, Journal of Applied Mechanics, vol.70, issue.1, pp.58-63, 2003. ,
DOI : 10.1115/1.1530635
A nonconforming finite element method for fluid???structure interaction problems, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.17-18, pp.17-182088, 2006. ,
DOI : 10.1016/j.cma.2005.01.017
A stable time advancing scheme for solving fluid???structure interaction problem at small structural displacements, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.2, pp.210-222, 2008. ,
DOI : 10.1016/j.cma.2008.07.010
Computational Methods for Parachute Fluid???Structure Interactions, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.125-169, 2012. ,
DOI : 10.1007/s11831-012-9070-4
Stabilized Finite Element Formulations for Incompressible Flow Computations, Advances in applied mechanics, pp.1-44, 1992. ,
DOI : 10.1016/S0065-2156(08)70153-4
Numerical Benchmarking of Fluid-Structure Interaction: A Comparison of Different Discretization and Solution Approaches, Fluid Structure Interaction II, pp.413-424, 2010. ,
DOI : 10.1007/978-3-642-14206-2_15
Added Mass Effects of Compressible and Incompressible Flows in Fluid-Structure Interaction, Journal of Applied Mechanics, vol.76, issue.2, pp.21206-21213, 2009. ,
DOI : 10.1115/1.3059565
Partitioned iterative solution methods for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.193, issue.2, pp.3-27, 2011. ,
DOI : 10.1002/fld.2465
Flux Evaluation in Primal and Dual Boundary-Coupled Problems, Journal of Applied Mechanics, vol.79, issue.1, pp.10904-010904, 2011. ,
DOI : 10.1115/1.4005187
A numerical model of cellular blebbing: A volume-conserving, fluid???structure interaction model of the entire cell, Journal of Biomechanics, vol.43, issue.2, pp.210-220, 2010. ,
DOI : 10.1016/j.jbiomech.2009.09.025
