New interface
Conference papers
Using Cooja for WSN Simulations: Some New Uses and Limits
Kévin Roussel 1, 2, 3 Ye-Qiong Song 1, 2, 3, 4 Olivier Zendra 5
Abstract : The Cooja/MSPSim network simulation framework is widely used for developing and debugging, but also for performance evaluation of WSN projects.We show in this paper that Cooja is not limited only to the simulation of the Contiki OS based systems and networks, but can also be extended to perform simulation experiments of other OS based platforms, especially that with RIOT OS.Moreover, when performing our own simulations with Cooja and MSPSim, we observed timing inconsistencies with identical experimentations made on actual hardware. Such inaccuracies clearly impair the use of the Cooja/MSPSim framework as a performance evaluation tool, at least for time-related performance parameters.We will present in this paper, as our contributions: On the one hand, how to use Cooja with projects not related to Con-tiki OS; On the other hand, the detailed results of our investigations on the inaccuracy problems, as well as the consequences of this issue, and give possible leads to fix or avoid it.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01240986
Contributor : Kévin Roussel Connect in order to contact the contributor
Submitted on : Friday, February 26, 2016 - 11:02:27 AM
Last modification on : Monday, July 25, 2022 - 3:44:06 AM
Identifiers
  • HAL Id : hal-01240986, version 2
Citation
Kévin Roussel, Ye-Qiong Song, Olivier Zendra. Using Cooja for WSN Simulations: Some New Uses and Limits. EWSN 2016 — NextMote workshop, ACM, Feb 2016, Graz, Austria. pp.319‒324. ⟨hal-01240986v2⟩
Share
Metrics
Record views
817
Files downloads
4237
