Journal articles
Tight Bounds for Distributed Minimum-Weight Spanning Tree Verification
Abstract : This paper introduces the notion of distributed verification without preprocessing. It focuses on the Minimum-weight Spanning Tree (MST) verification problem and establishes tight upper and lower bounds for the time and message complexities of this problem. Specifically, we provide an MST verification algorithm that achieves simultaneously O(m) messages and O(√ n+D) time, where m is the number of edges in the given graph G, n is the number of nodes, and D is G's diameter. On the other hand, we show that any MST verification algorithm must send Ω(m) messages and incur Ω(√ n + D) time in worst case. Our upper bound result appears to indicate that the verification of an MST may be easier than its construction, since for MST construction, both lower bounds of Ω(m) messages and Ω(√ n+D) time hold, but at the moment there is no known distributed algorithm that constructs an MST and achieves simultaneously O(m) messages and O(√ n + D) time. Specifically, the best known time-optimal algorithm (using O(√ n + D) time) requires O(m + n 3/2) messages, and the best known message-optimal algorithm (using O(m) messages) requires O(n) time. On the other hand, our lower bound results indicate that the verification of an MST is not significantly easier than its construction.
Complete list of metadata
https://hal.inria.fr/hal-01241088
Contributor : Amos Korman Connect in order to contact the contributor
Submitted on : Wednesday, December 9, 2015 - 9:48:52 PM
Last modification on : Friday, January 21, 2022 - 3:14:31 AM
Long-term archiving on: : Saturday, April 29, 2017 - 9:47:26 AM
ToCS-accepted.pdf
Identifiers
Collections
Citation
Liah Kor, Amos Korman, David Peleg. Tight Bounds for Distributed Minimum-Weight Spanning Tree Verification. Theory of Computing Systems, Springer Verlag, 2013, ⟨10.1007/s00224-013-9479-7⟩. ⟨hal-01241088⟩
Share
Metrics
Les métriques sont temporairement indisponibles
