Abstract : In this paper we give an overview of proof-search method for CTL model checking based on Deduction Modulo. Deduction Modulo is a reformulation of Predicate Logic where some axioms—possibly all—are replaced by rewrite rules. The focus of this paper is to give an encoding of temporal properties expressed in CTL, by translating the logical equivalence between temporal operators into rewrite rules. This way, the proof-search algorithms designed for Deduction Modulo, such as Resolution Modulo or Tableaux Modulo, can be used in verifying temporal properties of finite transition systems. An experimental evaluation using Resolution Modulo is presented.
