Conference papers
Closed-Loop Autofocus Scheme for Scanning Electron Microscope
Le Cui 1 Naresh Marturi 2 Eric Marchand 1 Sounkalo Dembélé 2 Nadine Piat 2
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : In this paper, we present a full scale autofocus approach for scanning electron microscope (SEM). The optimal focus (in-focus) position of the microscope is achieved by maximizing the image sharpness using a vision-based closed-loop control scheme. An iterative optimization algorithm has been designed using the sharpness score derived from image gradient information. The proposed method has been implemented and validated using a tungsten gun SEM at various experimental conditions like varying raster scan speed, magnification at real-time. We demonstrate that the proposed autofocus technique is accurate, robust and fast.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01241470
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Thursday, December 10, 2015 - 3:23:09 PM
Last modification on : Friday, January 21, 2022 - 3:09:05 AM
Long-term archiving on: : Friday, March 11, 2016 - 3:54:36 PM
File
ISOT2015_lcui_V1.pdf
Identifiers
Citation
Le Cui, Naresh Marturi, Eric Marchand, Sounkalo Dembélé, Nadine Piat. Closed-Loop Autofocus Scheme for Scanning Electron Microscope. Int. Symp. of Optomechatronics Technology, ISOT 2015, Oct 2015, Neuchatel, Switzerland. ⟨10.1051/matecconf/20153205003⟩. ⟨hal-01241470⟩
Share
Metrics
Record views
259
Files downloads
537
