Long-term Temporal Convolutions for Action Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Typical human actions last several seconds and exhibit characteristic spatio-temporal structure. Recent methods attempt to capture this structure and learn action representations with convolutional neural networks. Such representations, however, are typically learned at the level of a few video frames failing to model actions at their full temporal extent. In this work we learn video representations using neural networks with long-term temporal convolutions (LTC). We demonstrate that LTC-CNN models with increased temporal extents improve the accuracy of action recognition. We also study the impact of different low-level representations, such as raw values of video pixels and optical flow vector fields and demonstrate the importance of high-quality optical flow estimation for learning accurate action models. We report state-of-the-art results on two challenging benchmarks for human action recognition UCF101 (92.7%) and HMDB51 (67.2%).
varol2016.pdf (2.06 Mo) Télécharger le fichier
hal-01241518 , version 2 (15-04-2016)
hal-01241518 , version 3 (02-06-2017)
Gül Varol, Ivan Laptev, Cordelia Schmid. Long-term Temporal Convolutions for Action Recognition. 2016. ⟨hal-01241518v2⟩
8134 Consultations
2175 Téléchargements
